Old Mar 12, 2012, 06:12 AM
mackie is offline
Find More Posts by mackie
PCM - Pro. Crash Master
mackie's Avatar
USA, PA, Maytown
Joined Jan 2010
Originally Posted by valiantGLX View Post
It has a shonky gyro, straight up!
It is the heading hold technology (I think thats what it is called) to be more specific. When you have a working mCX2, hold it in your hand, throttle it up, then spin it around, you can see the two sets of rotors independantly speeding up and slowing down to counter act the twisting motion.This is to help to keep your heli flying in whatever direction you point it.
THE FIX: There is no fix You will need a new 5-in-1 board.
This is a long shot but worth trying Disconnect your 5-in-1 from your heli then throw it against the ground, cross your fingers, re-connect it to the heli then cross your toes too, plug in the battery, give the board a little kiss, then attempt to take off
THE REASONING: I really have no idea, but I suspect the heading hold thingy may be analog, meaning there may be a tiny little ball in a tiny little cage to tell the 5-in-1 what direction it is flying. Why do I think this???? 'Cause it sure as hell don't have GPS technology. So an educated guess would suggest that the tiny little ball in a tiny little cage is jammed and telling your heli to counter act twisting motion un-necessarily, and the shock of throwing it against the ground may dislodge it. A magnet may work too!
What have you got to loose??? you are gonna need a new 5-in-1 anyway
ROFLMAO A little duct tape and a hammer will fix anything I am having simular problems with mine, gonna sit down with the tx and play with the rudder settings a while (I have a magnet to try first too,lol ) Has anyone tried any of these "upgrades" to their mcx2 http://www.micro-flight.com/BLADE-MCX.htm I like the idea of the small scale heli thx
mackie is offline Find More Posts by mackie
Old Mar 12, 2012, 06:54 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
MIA was a big dealer with small heli's until people ran into a problem with the looooooong wait for their stuff. Mario lost momentum because of it and guys were staying away. Some of the stuff was a little hokey. Maybe things have changed. I was on another site today and saw Mario pushing new canopies for the Eflite MQX. He's got all kinds of stuff on there trying to drum up business.
kodak_jack is offline Find More Posts by kodak_jack
Old Mar 12, 2012, 02:25 PM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
FWIW, I ordered an MD500E canopy kit (blue) for an MCX last month. It turned out that he had that canopy in stock and so I received it very quickly. I had enough spare MCX/MCX2 parts lying around that I figured I'd grab another MCX 5-in-1 and build a scale model to add to my fleet. Overall it was a very positive experience for me (my first scale kit build). The materials are very lightweight and so some care needs to be taken to make sure they hang properly from the helicopter but otherwise I'm quite satisfied with the project. I've bounced the helicopter off of the fiberglass skids quite a few times and they've held together very well.
The only issue that I had was that the canopy and skids added about 3 ounces to the overall weight of the mCX. To compensate, I had to put mCX2 motors into the helicopter but once I did that I found that it flies very well. In fact, ithe combination of the mCX 5-in-1 and mCX2 motors gives it so much juice, I think I'm going to have to re-do the throttle curve on my DX6i so that it's a little more uniform. I have to be careful not to let it bang the ceiling when I take off! I also need to use 25C batteries (I use Thunderpower) rather than the 14C stock E-Flite batteries. I also used a spare mCX2 swashplate, flybar, and blades.
I'd been considering posting a separate thread about my build experiences (with pix) but I figured that since I'm such a latecomer to this game, I figured people have all already seen this stuff.
RoboHeli is offline Find More Posts by RoboHeli
Old Mar 12, 2012, 03:24 PM
valiantGLX is online now
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
You had more luck than me, when I connected my mCX 5-in-1 to my mCX2 mainframe and motors it fried the mCX 5-in-1. While it had heaps of power, it would spin out of control in 1 direction with every burst of throttle. But when it was hovering at any particular height it would fly fine. When I connected my mCX 5-in-1 back on to my S300 the same issue continued to persisted.
valiantGLX is online now Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Mar 12, 2012, 03:47 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
I was worried about potentially frying something, too. So, I called Horizon Hobby and asked them about it before I did anything and they said it would be okay. I also discussed this mod with RGC user "Bill Glover" after I found this post:
http://www.rcgroups.com/forums/showp...2&postcount=12
(from the thread http://www.rcgroups.com/forums/showthread.php?t=1538152)
where he described doing exactly the same thing with his MIA MD500E MCX conversion and having no troubles with his mCX2 motors being driven from an MCX 5-in-1. Before I committed to it, I PM'd him to ask him about it since it's been a few months since he did it and he said it's been working fine.
Old Mar 12, 2012, 04:53 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
I dont know what hapened with mine then I ended up salvaging the servos and throwing it out.
I then scored an mCX2 5-in-1 cheap from ebay, and added that to my S300
Old Mar 15, 2012, 01:36 PM
thinman is offline
Find More Posts by thinman
Joined Dec 2008
I just bought the MCX2 BNF and noticed that it came with the new 150mah battery. It's the same one as HH currently has on backorder. I was wondering if this nano-tech 160mah battery will fit in the MCX2 and if anyone has used it? The 150 is 6mm thick where the 160 is listed as being 8mm thick. The other diminsions appear to be the same.
BTW. I did notice that the new 150 comes with a sleeve spacer on it.
Bob
http://www.hobbyking.com/hobbyking/s...zone_Etc_.html
thinman is offline Find More Posts by thinman
Old Mar 15, 2012, 02:07 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Bob
Yes, the nano tech 160mah's will fit. That is what I use.
zmonster97 is offline Find More Posts by zmonster97
Old Mar 15, 2012, 03:50 PM
thinman is offline
Joined Dec 2008
Thanks Z....now if they will just get some in stock.
Bob
Old Mar 15, 2012, 08:37 PM
kodak_jack's Avatar
Joined Mar 2008
The same battery is used on the Champ and other micro planes. They use Velcro to hold the battery in place. You attach Velcro to the sleeve and it works with the plane. You slip the battery out of the sleeve and it works on a lot of other things.
Old Mar 16, 2012, 01:02 PM
NickBee is offline
Find More Posts by NickBee
Flanders, NJ USA
Joined Jan 2001
just got one of these for the office... Quick question. Do the leds on the chopper give you some kind of indication when your battery is "low". Meaning, it's time to land and charge the battery.
Thanks!
NickBee is offline Find More Posts by NickBee
Old Mar 16, 2012, 01:39 PM
North_of_49 is online now
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Thanks!
Nick,
the blue one on the main board does... but by the time it starts blinking you're already hitting LVC (low voltage cutoff) and coming down whether you want to or not
... as you are not new to RC, you probably already know this... but the general consensus is to not run the battery to LVC anyway... will degrade it over time. If you've done it already, and have noted how long your flight time was, use a timer from now on and cut that time short by about a minute or so... if the life of the battery mattery matters to you.
North_of_49 is online now Find More Posts by North_of_49
Old Mar 16, 2012, 09:53 PM
NickBee is offline
Flanders, NJ USA
Joined Jan 2001
Originally Posted by North_of_49 View Post
Nick,
Perfect. What is the name of the type of connector these battery use. I can rig up my Lipo meter to check batt voltage based on time. Thanks!
Edit... Nevermind I found it on eBay.
Old Mar 16, 2012, 10:38 PM
Joined Dec 2011
Yeah, Ultra Micro.
Old Mar 19, 2012, 08:23 PM
RoboHeli is offline
RoboHeli's Avatar
Joined Dec 2011
Hey, has anybody ever tried the "MIA Flybar Stability Tuning Kit" which consists of little red weights that you screw onto the ends of your flybar? It seems like a recipe for disaster with the potential for one of those to "slip" off and go blasting off like a little bullet...
Given that these were designed for the mcx, I wondered if anybody here had ever used them and could comment on them.
Sold Eflite Blade MSR Plus 2.4ghz Eflite Transmitter soaringcam Aircraft - Electric - Helis (FS/W) 4 Apr 07, 2010 10:27 AM
Sold EFLITE BLADE MSR+BLADE 400+DX6i dhmojo Aircraft - Electric - Helis (FS/W) 7 Mar 29, 2010 10:38 PM
Sold Blade MCX2 LNIB mgroves Aircraft - Electric - Helis (FS/W) 1 Mar 23, 2010 11:17 AM
For Sale Trade, eflite blades for eflite blades....Sell Blade CP Pro NIB with extras. kdill2160 Aircraft - Electric - Helis (FS/W) 1 Sep 02, 2006 09:28 AM
Alert Eflite Blade CX - 2nd Eflite heli jschenck Coaxial Helicopters 26 Oct 24, 2005 01:48 AM
