Old Mar 22, 2015, 07:12 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Question
Repairing intake tube on OS61FS
I've got this old OS61FS that was running fine until my FB corkscrewed my Cub into the ground for me. The engine was pushed back into the fuse and it creased the intake tube. Do you guys think I can just take this off, heat it up and run a screwdriver or something through it to expand it back to close to its original shape? I doubt I'll be able to find a replacement part unless someone's just got one laying around in a junk box. It was a sweet running engine until it was crashed.
JohnsPop is offline Find More Posts by JohnsPop
Old Mar 22, 2015, 08:09 PM
Broken Wings is offline
Find More Posts by Broken Wings
Broken Wings's Avatar
United States, FL, Cocoa
Joined Jan 2006
The 90 degree bend looks ok, as does the section that enters the carburetor. There's no heat to worry about. Could you splice a new section of K&S tubing in between? ... just a thought.
Broken Wings is offline Find More Posts by Broken Wings
Old Mar 22, 2015, 08:16 PM
SRQFlyer is online now
Find More Posts by SRQFlyer
Master re-kitter
SRQFlyer's Avatar
Sarasota, Florida
Joined Dec 2005
Intake tube
The Magnum and ASP engines are clones of the OS line. You may be able to substitute a tube from either HK or Hobby People.
Good luck,
Jim
SRQFlyer is online now Find More Posts by SRQFlyer
Old Mar 22, 2015, 08:58 PM
the pope is online now
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
Perhaps if you could mount the carb in a different position then a repaired part wouldnt need to be that precise like maybe the laser line of engines for example . That said I must congratulate you on the crash , that tube is knackered ! Cheers the pope
the pope is online now Find More Posts by the pope
Old Mar 23, 2015, 06:08 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
If you have the tools, you could replace the tube with a new one by making it. But maybe splicing in a new tube would work too. Silver solder the splice or JB Weld epoxy it maybe. I think there are some tubing sizes that would work from the K&S metals display at hobby shops or ACE hardware or Hobby Lobby or stores like that.
earlwb is offline Find More Posts by earlwb
Latest blog entry: My new Gaui X5 Rc Helicopter
Old Mar 23, 2015, 07:47 AM
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Hadn't thought about a Magnum tube replacement. I guess that'd be the best first option, to see if I could get a replacement from them. And I swear Pope, it was my FB that crashed it not me! LOL
Old Mar 23, 2015, 09:16 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
If you use a Magnum intake manifold be sure the face connecting bolts to the head are correctly orientated. Newer Magnum manifolds changed their bolt pattern on their newer engines from the old engines, so make sure you get the correct one.
Chip01 is offline Find More Posts by Chip01
Old Mar 23, 2015, 09:19 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
There is a compound bend in the tube and it's smashed in that area. It doesn't look like cutting and splicing will be a simple fix.
Which Sanye (ASP, Mangum) engine do you guys suggest for substitution? I can't think of one that will be a drop in.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Mar 23, 2015, 10:02 AM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
What's an FB?
Pretty tricky to repair that damage .... but, I have seen crushed tubes that have been successfully ironed out. Worth a go.
Could even try plastic tube, or thin-walled silicone tubing, slotted onto the stub of the damaged manifold. I think that might give you a fairly pleasing repair.
Alternatively, one could be fabricated from straight brass tube. It won't matter that the joint is 90 degrees, rather than a smooth bend. Of course, if you can bend that K and S stuff, then that's even better.
Or, you might have the carb fastened to a short stub, like on my YS.... see pic below.
bogbeagle is online now Find More Posts by bogbeagle
Old Mar 23, 2015, 01:42 PM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
If this is any help, here are some pictures of how I did bend pipes for a Technopower radial. Do use fine 'dry' sand and get old of an apropriate bending tool. Fill the tube and put stops at both ends. And use a tube that is longer than needed so it can be handled well in the bender.In this case two bends have to be made and in view of the short distance this may be tricky, never done that myself.
Reginald is offline Find More Posts by Reginald
Old Mar 23, 2015, 01:44 PM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
xxxx
Old Mar 23, 2015, 01:50 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Also if you use the brass tubing like from K&S, you can heat it up good first to anneal it so it is softer and more easy to work with. You can use a gas stove or a torch, but you simply heat it until it is cherry red color. Then let it cool. We do the same thing with the brass fuel tubing too.
Old Mar 23, 2015, 01:57 PM
Joined Mar 2007
K and S sells a little set of bending springs, which do work quite well.
Old Mar 23, 2015, 02:02 PM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
I had these years ago but could never work well with them, problem is how to retrieve the springs in fe a 90 bend ? I never managed that...
Old Mar 23, 2015, 02:05 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yes I was just going to say that trying to get the spring off after putting in a nice bend was a problem for me too.
Found Intake tube for Saito FA-65 ae4sh Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 24, 2014 06:13 AM
Sold Os max h 80 rear intake side exhaust motor for parts or repair free shipping CADILLAC200 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 28, 2014 03:01 PM
Question intakes on side of intake. shadowolfs Electric Ducted Fan Jet Talk 16 Oct 03, 2013 06:16 AM
Wanted Need intake manifold for OS61FS Lane Jorgensen Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 28, 2013 01:27 PM
Found Alfa Models F86 Nose/Intake tube. Buzz Bomb Aircraft - Electric - Jets (FS/W) 0 Jul 08, 2006 05:38 PM
