Old May 12, 2014, 07:16 PM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Careful!
HV160 up in flames
Was setting up my EDF for my plane.
Bought an advertised as unused ESC from someone on RC groups a while ago
plugged in 8S pack on the Castle ICE2 HV160
Everything plugged in, slowly raise the throttle, nothing, then buzzing noise then whooosh, flames coming out the ESC.
Pulled the battery packs off it. Went to unplug it from the motor and the black lead pulled right out, probably de-soldered from the heat
Smoked for a little bit, stunk up the cellar
Only good news is that it wasn't in the plane when it happened
I checked the motor with a different ESC and it works fine.
So time to get a new ESC I guess
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old May 12, 2014, 09:29 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Somethings not right. That should have worked unless your motor has a short or was blocked from turning???
4stripes is online now Find More Posts by 4stripes
Old May 12, 2014, 10:24 PM
lrb75 is online now
Find More Posts by lrb75
United States, VA, Springfield
Did it have all the updates?
lrb75 is online now Find More Posts by lrb75
Old May 13, 2014, 06:11 AM
Narragansett, RI
Joined Oct 2000
Nope, see above, motor worked fine
Old May 13, 2014, 06:17 AM
4stripes's Avatar
Joined Jan 2009
Send it to Castle as their customer care is very good.
Old May 13, 2014, 08:06 AM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
+1
I bought an ice160 at the LHS last year at 75% off the price then found out there was a recall on the ice160. I only paid $80. for it so I thought I would have to paid a balance... Nope Castle sent me a brand new edge 160 at no charge and a neck strap as well. Great Customer Service every time I'm sure they will help you out!
BadLemon is offline Find More Posts by BadLemon
Old May 13, 2014, 12:48 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Bet if was a recall version.
Madmax1965 is offline Find More Posts by Madmax1965
Old May 13, 2014, 06:15 PM
charlieoneseven is offline
Find More Posts by charlieoneseven
Aircrafting is noisey...what?!
charlieoneseven's Avatar
United States, CA, Long Beach
Joined Dec 2005
Ken I know how it feels I was plugging in a new esc mounted on the plane with the cowl removed a few weeks back and I saw a red light and smoke coming from it so I unplugged it and the red light went out and the smoke stopped but the esc is not working at all now. There is no red light on the esc it was one of the components turning red hot it even melted a hole In The Heat shrink.
Time to send it back although it had never been run before it is an older one and installed in that plane maybe 5 years before the plane was finished. CC 85 HV
charlieoneseven is offline Find More Posts by charlieoneseven
Old May 13, 2014, 07:18 PM
Narragansett, RI
Joined Oct 2000
Well its all packed up to be sent back to Castle for "repair"
Its $155 to repair out of warranty, still cheaper than a new one
I'll cross my fingers and hope the replace it for free
Old May 14, 2014, 10:56 AM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Word is YEP 150 or 180
Old May 14, 2014, 12:03 PM
Lboogie is offline
Find More Posts by Lboogie
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
I had a CC HV160 do that to me also. It was a few years ago. The replacement worked just fine. I remember they stated a manufacturer spec change in some component caused the failures in a batch.
L
Lboogie is offline Find More Posts by Lboogie
Old May 14, 2014, 03:47 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
The YEP 120 FETs actually can do 140 on 12s EASY with heatsink, air and AFW turned on...
YEP isn't perfect , it will not survive an arching of the motor connections or even a short between any of the 3 rails ... I use the SOLID (none of the banana connector) 4 and 5mm connectors and tape around the connectors with mine to prevent this.
For the price I've not had to worry one bit though connecting to a pack
erh7771 is offline Find More Posts by erh7771
Old May 14, 2014, 06:13 PM
nerv is offline
Find More Posts by nerv
nerv's Avatar
United States, CA, San Jose
Joined Jan 2007
The only thing may survive the 3 rails short is the good old HobbyWing 120hv. I had it happen before, melted all 3 motor wires, smoke coming out from the plane, and the ESC got extremely hot, but it survived.... and had many flights without problem afterwards. That thing is close to bulletproof.
nerv is offline Find More Posts by nerv
Discussion hobbytron picco z goes up in flames after..... lilmc53 Micro Helis 15 Jan 11, 2007 05:17 PM
Discussion Is my Magister Motor going up in flame? (Picture Attached) asm_ Foamies (Kits) 24 Jul 11, 2006 06:38 AM
Discussion Is my Magister Motor going up in flame? (Picture Attached) asm_ Power Systems 0 Jul 05, 2006 06:35 PM
Up in flames zpat Batteries and Chargers 15 Apr 08, 2005 12:10 PM
E-Starter Up in Flames.......... Cal Electric Plane Talk 33 Jan 02, 2005 07:40 PM
