Old Apr 07, 2014, 01:22 PM
steve bisco is offline
Find More Posts by steve bisco
canvey island
Joined Jul 2002
Well im running, Castrol Power Racing 2T its what I run in my Yamaha RD 500, fully synthetic Thats why I asked on here as I only ever run 20.1 or 25.1 in my other boats and cars, but never had a tuned engine before.
steve bisco is offline Find More Posts by steve bisco
Old Apr 07, 2014, 02:49 PM
Ron Olson is offline
Find More Posts by Ron Olson
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Really. It seems like all you know are weedies from your gallery. When you start running higher HP and RPM engines you need the extra protection that the oil gives you. My modded motors are pumping out Dyno'ed 7 HP. 8 oz. per gallon is low, some are using 10oz. per gallon.
Ron Olson is offline Find More Posts by Ron Olson
Old Apr 15, 2014, 05:17 AM
632bigduke is offline
Find More Posts by 632bigduke
BAH MINI H 4 Life
632bigduke's Avatar
Joined Sep 2013
632bigduke is offline Find More Posts by 632bigduke
Old May 01, 2014, 11:42 PM
Tahoe1970 is offline
Find More Posts by Tahoe1970
Joined Jan 2014
Originally Posted by 632bigduke View Post
If you want to see 80+ get a 2818 round tips , back cut 1/8" and cupped ABC PROP from Chris at dasboata tell him what it's for . ( don't get saw monster right now it will be your enemy )
You'll need a 90* hot pipe ( your pipe ant gonna cut it ) and can you tell me from the back of the boat to the center of the spark plug mersuerment is ?
I can help you get it popping !!!
I was tault by the BEST :-)
I've got 2 classone / Rico and 3 36" Sprintcats
You'll need to understand prop and STRUT adjustments if you EVER WANT TO SEE 80
Good luck
http://m.ebay.co.uk/itm/290953704722
LMAO - yeah ok
Tahoe1970 is offline Find More Posts by Tahoe1970
Old May 02, 2014, 04:49 AM
canvey island
Joined Jul 2002
Well Guys put GPs in it and its hitting 51mph on a 67mm prop, sounds like I could go up on the prop size as engine revving high
Old May 02, 2014, 05:52 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Hey Wally, slumming it?
Tell him what he needs then.
Old May 02, 2014, 11:19 PM
Joined Jan 2014
I don't say much cuz there's so many little changes that add up and once you make those changes and Tweeks they pay off Big. It's great to give advice on a particular prop , but unless the guy can bolt it on and see instant improvement , which with a dragcat is very rarely . Running 80+ with that boat isn't as easy as selecting a prop. But since he's only at 51mph then a sharpened and balanced 2716/15* could get mid 60's to low 70's fairly easy if you spent a little time tuning and adjusting strut.
Old May 03, 2014, 09:03 AM
canvey island
Joined Jul 2002
Guys im new to all this, I don't even know what size a 2716/15* prop is, all I know it came with a Prather 275 which it does not like and I went down to an octura 467 that gives me 50mph. The distance from center of the spark plug to the back of boat is 13.5 inches and the center line of the prop is an inch lower than the center of the tunnel, hope this helps, would like to get into the 60mph bracket so any help would be appreciated, if you listen to the motor in the vid would you say its revving too high?
Steve
Old May 03, 2014, 04:07 PM
Joined Jan 2014
Steve , you want to get into the 60mph bracket and any help would be appreciated.
What am I missing here ? Isn't that what I just gave you ?
Old May 03, 2014, 05:54 PM
txt killer is offline
Find More Posts by txt killer
Joined Apr 2008
What size is this motor? A Zenoah and Homelite can push a Prather 275 prop no problem. It certainly isn't 25cc or 30 cc.That would explain the funky oil ratio. You want to go faster than 50 mph then get the new Zenoah G320.
txt killer is offline Find More Posts by txt killer
Old May 03, 2014, 07:11 PM
sleepwalker is online now
Find More Posts by sleepwalker
sleepwalker's Avatar
United States, PA, Clearfield
Joined Jan 2007
Steve ,I looked up the oil your using and it says it's for motorcycles and scooters,nothing mentioned about using it in marine engines. I did find Castrol 2 cycle outboard oil for premix or injection engines.Maybe that's what you should be using. http://productsforyou.castrol.co.nz/...-Outboard-2T/2
sleepwalker is online now Find More Posts by sleepwalker
Old May 04, 2014, 09:22 AM
Joined Apr 2008
If it is a Zenoah then he shouldn't have a problem using a Prather 275 prop with no problem. It's more Hp than a Homelite which I have and use a Prather 275 prop. A Zenoah G260 is more than 4.5 hp with a tuned exhaust. I suspect he bogged down the engine with 16:1 oil ratio. LOL
Old May 04, 2014, 04:00 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
I don't think so txt. High HP engines run better with smaller diameter props, 67-70mm.
Old May 05, 2014, 03:59 PM
canvey island
Joined Jul 2002
I think a 70mm is what I need, out tomorrow will have a play with strut, also got some fast brushless to play with and nitro
Old May 06, 2014, 12:57 AM
Joined Jan 2014
Lmao Ron , yeah that worked really well 😁
Sold 1/16 e-revo vxl in great condition + night setup rally vxl conversion kit rc4u Cars - Cars and Parts (FS/W) 2 Oct 15, 2013 10:51 AM
Sold 1/16 e-revo vxl in great condition + night setup rally vxl conversion kit rc4u Cars - Trucks and Parts (FS/W) 1 Oct 07, 2013 01:06 PM
Discussion M25 Tank Transporter, M26 Pacific in 1/16 Scale ussd90 RC Tanks 0 Sep 28, 2013 04:33 AM
Cool Look what the cat dragged in... Sid3ways Multirotor Talk 6 Apr 12, 2012 05:54 AM
Help! What the Cat Dragged In... mdickey Sport Planes 13 May 22, 2010 10:12 AM
