This thread is privately moderated by leadfeather, who may elect to delete unwanted replies.
Old Dec 15, 2013, 07:34 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Data
VTOL RC aircraft concepts, designs and links
If you guys are like me, you enjoy seeing all the great designs and ideas for VTOL. I thought it might be a good idea to make it easier to do this for all by gathering and organizing the many designs into this thread. I'll do my best to include everyone's work...just give me some time to put this together and getting the organization right. Also, any help in getting all the VTOL work and builds included is greatly appreciated.
I'll try to post the designs in each category in chronological order as best I can.
The VTOL wheel below came from this web site: http://www.vstol.org
Tilt rotor
Scale or semi scale
EDF (as primary lift fan(s) )
Tricopter
Quadcopter
Bicopter
Single Fan
Tilt wing
Scale or semi scale
Tricopter
Quadcopter
Bicopter
Tail Sitter
Scale or semi scale
Single rotor
Two rotor
Tricopter
Quadcopter
Tilt Craft
Tricopter
leadfeather is offline Find More Posts by leadfeather
Old Dec 15, 2013, 07:42 AM
Winging it >
Joined May 2006
Tilt Rotor Designs
Scale:
Googleplex's V-22 Osprey; note use of flybars. circa 2009
V-22's Full fuse build of Rotormasters V-22 Osprey; circa 2011
f35vertical's F-35 circa 2012
Tom Stanton's V-22 Osprey Tilt Rotor 2nd version added to thread 2014
MrJan's "Valor V-280"
Single Fan:
Tom Hunt's design, Vertigo ... Video of the Vertigo circa 1994
Co-axial Rotors
Tilitrotorcoaxial's Coaxial rotor tilt wing circa 2010
Dual Fan:
Yellow-BL dual fan tilt rotor circa circa 2009
Andreas's modified Minimag tiltrotor circa 2010
BleskCZ's Eso-x1 VTOL circa 2011
TriCopter:
Cyber Defence System's Cyber Scout circa 2005
taileron's rc edf vtol circa 2007
leadfeather's F-35b Wii Jet circa 2011
leadfeather's Hover-EZ circa 2011
leadfeather's Flying Monkey circa 2012
foam and tapes' Chimera circa 2013
Stephen Carlson's Orange Hawk circa 2013
BirdsEyeView Aerobotics' FireFly6 circa 2014
Quadcopter:
sergiot78's Verti VTOL circa 2008
foam and tape's Quad Tilt Rotor circa 2011
Jonathan Hesselbarth's Wingcopter circa 2012
Ran D. St. Clair's Quad Tilt Rotor Bixler circa 2013
leadfeather's Jump Jet , no control surface experiment. circa 2012
ComQuest Ventures' Quad pusher tilt rotor Vertex. circa 2014
leadfeather's Quad Otter circa 2015
Winging it >
Joined May 2006
Tilt Wing Designs
Scale
Ran D. ST. Clair's Xc-142 circa 2013
Shenzhen Unique Model's CL-84 circa 2014
RCScopes' Ducted fan X-35B circa 2015
Single Fan:
Co-axial Rotors
Tilitrotorcoaxial's Coaxial rotors tilt wing circa 2010
Tilitrotorcoaxial's Coaxial rotors free wing Circa 2010
Dual Fan:
Air Hog's Osprey; flybar stabilized circa 2010
foam and tape's Twins Cargo Plane circa 2010
TriCopter:
Greg Covey's Multiplex Magister converted tilt wing circa 2008
RWTH-Aachen University Tilt-Wing Tricopter circa 2011
Quadcopter:
Old Dec 15, 2013, 07:45 AM
Winging it >
Joined May 2006
Tilt Craft, Separate lift/thrust, Stop Rotor and other designs
Tilt Craft
PatOg's POGL018 VTOL circa 2013
QuadPlane's Zero Transiton VTOL ... video circa 2013
Quadcopter or Tricopter lift, separate motor(s) for forward flight.
Drew Blair's Dual tails VTOL Jet Plane, Tricopter stabilized tilting turbine engine. circa 2007
RidiculousMJM's VTOL edf jet 4 lift edfs + pusher prop. circa 2010
Marcus Peter and Wolferl's VTOL-Nuri 4 lift fans + pusher fan. circa 2010
EddieWeeks' Tricopter + dual thruster wing circa 2013
Ran D. St. Clair's Fun Cub VTOL circa 2013
Siniger's Siniger One VTL
AJWoods' Micro VTOL Vapor circa 2014
AJWoods' Quad Harrier Hybrid circa 2014
Serg Alexandrov's Region Angel, quad rotor lift + pusher airplane
Serg Alexandrov's AL-107 "Cyberlarus" quad rotor + pusher.
Stop Rotor
Stop Rotor Technologies Hybrid RotorWing circa 2013
Old Dec 15, 2013, 07:46 AM
Winging it >
Joined May 2006
Other non-hobby VTOLs concepts and cool ideas,
Israel Aerospace Industries Panther Tilt Rotor
Bell's Eagle Eye tilt rotor VTOL
NASA's electric Puffin
Zee Aeros 8 lifter + 2 thruster VTOL craft
NASA's Stop Rotor Samarai
Oliver Aircraft's HexPlane
Skikorsky Blown Wing
Boeing Phantom Swift
Latitude Engineerings Hybrid Quadrotor
Aurora Flight Sciences' VTOL Excalibur
AMV's AMV211 tilt craft circa 2003
Acuity technologies AT-10 VTOL ... youtube video
Aurora Flight Sciences Goldeneye 50, 80, and 100
Nasa's GL 10 "Greased Lightning"
Joby Aviation's S2
Joby Aviation's Lotus
X Craft's "X PlusOne"
Winging it >
Joined May 2006
Flight Controls and Stabilizers
KK
KK2
Multiwii very flexible fcb but very tedious programming required for VTOL use.
OpenAero2 , Derived from KK especially for VTOL
Gyros
Flybars
Old Dec 16, 2013, 12:39 PM
Ran D. St. Clair is offline
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
Leadfeather,
I am not sure if you are looking for input or not?
Example: Quadcopter lift, separate motor(s) for forward flight.
VTOL-FunCub
Build thread located here:
http://www.rcgroups.com/forums/showthread.php?t=1958738
Video Here:
R.D's Fun Cub VTOL (3 min 32 sec)
Ran D. St. Clair is offline Find More Posts by Ran D. St. Clair
Old Dec 16, 2013, 12:50 PM
Joined Dec 2006
Quad Tilt Rotor
Example: Quad Tilt Rotor
VTOL-Trainer
Video Here:
bobs modified Multiplex Bixler airplane hovering around sccmas (3 min 59 sec)
Build Thread Here:
http://www.rcgroups.com/forums/showthread.php?t=1814667
Build Instructions Here:
https://www.dropbox.com/s/590n4ds84u...tructions.pdf?
Old Dec 16, 2013, 05:57 PM
Winging it >
Joined May 2006
Ran, Yes I'm hoping for input from anyone and everyone who can contribute.
The way you posted is perfect too, photos, videos and relevant links... one post for one craft only preferably as you have done. That way I can link the post in this thread for a particular craft. The readers can then read the post and then decide to follow any provided links to go further.
Thanks!
Old Dec 16, 2013, 11:04 PM
Joined Dec 2006
Xc-142
XC-142, Stand-Off Scale, 5 motor Tilt wing
Build thread here:
http://www.rcgroups.com/forums/showthread.php?t=2008164
Video here:
Scale Flying model of XC-142 VTOL (16 min 27 sec)
Video by Walter Colby Productions.
Credit to David Thompson (HappySundays) for creating the OpenAero2-VTOL Firmware.
Old Dec 17, 2013, 10:18 AM
Winging it >
Joined May 2006
Thanks Ran. Hmmm so now how do we try to classify the Xc-142?
Does it fit the tricopter tilt wing category ( with redundant fans) or should we create a new slot for tilt wing many fans?
Old Dec 17, 2013, 05:44 PM
Joined Dec 2006
Leadfeather, I assumed that it was in the Tiltwing Scale or Semi Scale category. In pracitce it is most similar to a Tri-copter except that yaw is controlled by the ailerons, not tilting the tail rotor. I am not sure that the quad or tri categories mean much for a tilt wing. Even counting rotors is problematic since they aren't all the same size. It doesn't matter much to me. No matter what categories you come up with someone will come up with something that doesn't fit.
Old Dec 17, 2013, 06:07 PM
Winging it >
Joined May 2006
Dohhhh! I'm an idiot. Of course Tiltwing scale.
I think I'll be adding one more slot (for now) for some helicopter airplane hybrids I've seen.
Old Dec 18, 2013, 12:14 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Good idea starting this thread Lead. Here are some new entries into the world of VTOL I have seen.
The first one is a tilt ducted fan set up from Boeing. The second one is a tail sitter that looks like a Pogo and an Osprey had a baby.
RCvertt is offline Find More Posts by RCvertt
Build Log CPO's Modified Tricopter Design Concept : Building Around GoPro FOV cpo Scratchbuilt Multirotors 38 Feb 09, 2014 07:57 AM
Idea New VTOL concept - Hybrid Airplane/tricopter PatOg VTOLs 39 Jan 15, 2014 09:30 PM
Idea New VTOL concept - Hybrid Airplane/tricopter PatOg Scratchbuilt Multirotors 2 Dec 08, 2013 10:32 PM
Discussion Early VTOL concept GWFAMI VTOLs 0 Oct 19, 2007 11:20 AM
Discussion New concept of VTOL UAV... Rakma VTOLs 6 Oct 19, 2006 05:00 PM
