Old Dec 01, 2012, 10:14 PM
tigreflyer is offline
Find More Posts by tigreflyer
Joined Apr 2012
Like Squeezing The Trigger On A 1911A1 Target Pistol,
I've always tried to build in the perfect line pull weight in my planes. To get the same pull weight at 90 degrees that you get in level flight is the trick. If you have a plane that pulls harder in level flight than at 90 degrees, how would you trim it to attain perfect pull weight balance?
tigreflyer is offline Find More Posts by tigreflyer
Old Dec 01, 2012, 10:31 PM
JKinTX is offline
Find More Posts by JKinTX
Joined Jul 2012
Leadouts go forwards a tad.
JKinTX is offline Find More Posts by JKinTX
Old Dec 02, 2012, 09:56 AM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
Effectively you can't because (for a stunter at least) they develop around 3g in level flight from centrifugal force (let's not argue about centripetal ) but overhead gravity counteracts by 1G (naturally) leaving 2G for line tension. Any other line tension comes from aerodynamics/trim/engine offset/whatever.
downunder is offline Find More Posts by downunder
Old Dec 02, 2012, 10:15 AM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
Yes, move the leadouts forward. Do it a little at a time, like 1/8 inch. You can get it to where the pull feels similar level and in the overhead 8s, for example.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Dec 02, 2012, 12:30 PM
Joined Apr 2012
Running your engine a bit rich allows more lean out at 90 degrees resulting in a power and llifting increase. And, Eric Rule told me one of his propellers would pull the lines better above 45 degrees than the Zinger 10/6 I was using on my Brodak P40/OS Max .35 Stunt plane. He was right.
Old Dec 02, 2012, 03:25 PM
JKinTX is offline
Joined Jul 2012
But...
Move the leadouts ahead and the outward yaw angle is decreased- so the speed goes up a bit- you get slightly less tension in level flight, but the extra speed helps in the climb and overhead areas to gain more tension when it is needed there.
Discussion Just pulled the trigger on a Syma S033G Predreadnut Coaxial Helicopters 21 Jul 24, 2012 07:16 AM
Discussion Pistol Grip TX Trigger Mod? jrb Radios 7 Mar 03, 2012 06:29 PM
Discussion Pistol Grip TX Trigger Mod? jrb Car Talk 0 Feb 29, 2012 09:17 AM
Discussion Targeted adds from hobbyking? popping up on random sites NZ_Nitro Electric Ducted Fan Jet Talk 4 Feb 24, 2012 02:30 AM
Discussion Recommend a new target pistol rcjetpilot Life, The Universe, and Politics 86 Nov 24, 2010 12:02 AM
