This thread is privately moderated by soundcheque, who may elect to delete unwanted replies.
Old May 01, 2012, 03:35 AM
soundcheque is offline
Find More Posts by soundcheque
Bring It On !!!!!
soundcheque's Avatar
Newmarket, England.
Joined Aug 2006
Advice Required
I've recently been restoring an old Precedent Electrafly 2 metre powered glider.
A brief spell of inspiration caused me to cover the fuz with metallic builders tape which is a very thin self adhesive metal foil tape which looks like the steel panels on an aircraft.
A brilliant result but now i'm wondering,,,,,will my Spektrum AR600 be OK ???
The signal works well in my shop but have I made the wrong choice in covering which may reduce the quality of the connection between AR600 DSMX and DS6i DSMX ??
I didn't really want to buy the Carbon Fuz RX at 55 UK....
soundcheque is offline Find More Posts by soundcheque
Old May 01, 2012, 05:30 AM
vincent123 is offline
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
Range test
Do a range test, and you 'll know it soon.
If a problem, try to put the reciever in the wing, if the wing is not covered with alu foil.
vincent123 is offline Find More Posts by vincent123
Old May 01, 2012, 06:01 AM
Bring It On !!!!!
Newmarket, England.
Joined Aug 2006
Cheers for that..
I did a range check a few minutes ago,, the model isn't ready yet just awaiting the wing covering but I tried the range check on my balcony and scurried off down the other end of the flats !!!!
There's scaffolding erected also as the roof on the flats is being repaired and the range check was very satisfactory even with all this metalwork around.
Seems to be OK but I think I'll definately play safe and move it to either the wing section which has no alufoil or the cockpit canopy.
Thank You
Discussion Sig 600 Battery Requirements NEW222 Power Systems 6 Mar 01, 2012 04:37 PM
Help! required with compass reading michael f Hoverfly Technologies 14 Mar 01, 2012 07:48 AM
Help required designjem Non R/C Items (FS/W) 24 Mar 01, 2012 02:06 AM
Wanted Help required designjem Non R/C Items (FS/W) 0 Feb 28, 2012 12:09 PM
