Old Apr 07, 2012, 08:34 PM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
does the location of the 2.4 GHZ transmitter antenna, really affects its range ?
does the location of the 2.4 GHZ transmitter antenna, really affects its range ? from the actual performance point of view.
Here are the 3 posible positon.
1. a few inch away from the Transmitter Base such as Spektrum and JR
2. at the Base of Transmitter - Futaba, Aurora, Hitec
3. Inside the Transmitter - Newer Futaba
from the Theoretical Point of view, The further the Antenna from the Transmitter will give the Best Performance, due to Less obstacle on the Radiation Pattern........a Human Body can also act as as Obstacle......
here is my guest on the relative Performance of the 3 posible position:
1. a few inch away - this is the Best - 100%
2. at the Base of Transmitter - 99.9999% (base on a few inch compare to 1 Kilometer)
3. inside the transmitter - 99 %
I just hope someone can make a Measurable Performance comparison.
lazy-b is offline Find More Posts by lazy-b
Old Apr 08, 2012, 01:32 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
The position as orientation is more important than distance to transmitter.
So, keep antenna vertical, which is not easy inside body.
The "modern" no antenna radio solutions, which hide antenna inside radio making it horizontal are a big mistake and shouldn't be allowed for other than park flyers, imo.
Why consider your body as obstacle, are you pilot with the a... beeep... ... ? you should be always with the face to the plane.
renatoa is offline Find More Posts by renatoa
Old Apr 08, 2012, 06:59 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Two things:
1. The antenna emits strongest signal in a plane perpendicular to the antenna and almost no signal in line with the antenna.
2. We tend to face the aircraft which is anywhere from our level (on the ground) to high above our head.
Antenna pointed away from the pilot will point at the aircraft = minimum signal; antenna pointed up will send strong signal to aircraft on or close to the ground. Antenna pointing left or right will send the strongest signal to the aircraft regardless of its altitude if the pilot always faces the aircraft. So horizontal antenna is the best orientation.
ivanc is offline Find More Posts by ivanc
Old Apr 08, 2012, 07:22 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Do you mean vertical in relation to the ground? The transmitter is usually more or less horizontal, so this would mean bending it up at 90 degrees. Would you like to explain please.
My own practice is to bend it to one side (JR transmitter), on the theory that since I normally turn to face the model, this minimizes the probability of pointing the tip at the model.
But I should say that in five years of flying 2.4 (DSM2, Fly Dream, FrSky) I have had no cases of lost signal (except with an apparently defective AR500, which was not in any way a range issue) with any antenna orientation. I am astonished at the reliability of 2.4 after many years of flying FM.
Daedalus66 is offline Find More Posts by Daedalus66
Old Apr 08, 2012, 08:32 PM
podrieger is offline
Find More Posts by podrieger
Sarasota, FL
Joined Jan 2006
On a recent range test, I had 95 feet of range with the transmitter antenna horizontal (pointing to the right, horizontally). I moved the antenna to the vertical position ( pointing toward the ground at an angle) and my range went to 107 feet.
I think this relates to a previous post that the best reception is being perpendicular to the plane.
The radio was a Futaba 12FG and the receiver a 6008. The reason for the low range is I was testing the receiver inside a carbon tube sitting directly on the ground (worst way to range test). It proved that the antenna should be pointing toward the ground at the angle allowed and be perpendicular to the plane.
Phil
podrieger is offline Find More Posts by podrieger
Old Apr 09, 2012, 08:55 AM
Disarray is online now
Find More Posts by Disarray
Disarray's Avatar
United States, GA, Gray
Joined Apr 2007
Phil
This test could completely relate to the orientation of the antenna in the airplane. Best reception is when both antennas are in the same orientation, vertical to vertical, horizontal to horizontal.
Disarray is online now Find More Posts by Disarray
Old Apr 09, 2012, 12:58 PM
Sarasota, FL
Joined Jan 2006
Disarry,
The antennas in the carbon tube were horizontal with the tube laying on the ground. The range increased when the trans antenna was rotated to a vertical position. I was standing near 90 degrees to the tube.
I think this says the antennas were perpendicular to each other when the range increased..
Phil
Old Apr 09, 2012, 04:51 PM
Disarray's Avatar
Joined Apr 2007
Disarry,
Phil
Well so much for my fancy book learnin.
Wanted Cheap 2.4 ghz transmitter 7ender Aircraft - General - Radio Equipment (FS/W) 9 Mar 07, 2012 06:29 PM
Sold Cx2-3 2.4 ghz dsm Transmitter $35 shipped kevin finn Aircraft - General - Radio Equipment (FS/W) 0 Feb 23, 2012 06:17 PM
Sold $100 --- Futaba 9CA w/ FrSky 2.4 Ghz Internal Module + Proper Antenna JC Spohr Aircraft - General - Radio Equipment (FS/W) 7 Feb 23, 2012 03:52 PM
Help! Does adding a telescopic antenna next to the 2.4Ghz one affect range? Hamdhan Radios 2 Dec 07, 2011 09:46 AM
Discussion does the length of Coaxial Cable of 2.4 GHZ Antenna affect the performance of receive lazy-b Radios 23 Apr 30, 2011 01:19 PM
