Old Oct 13, 2009, 03:24 PM
WALLY ARCHER is offline
Find More Posts by WALLY ARCHER
Prop Buster
Clinton CT
Joined May 2007
STUFFING box
How to build a stuffing box on a flatbottom boat running a stock 540 motor??? THanks WAlly
WALLY ARCHER is offline Find More Posts by WALLY ARCHER
Old Oct 13, 2009, 04:07 PM
BOZINATOR is offline
Find More Posts by BOZINATOR
In The Sorrano Triangle
BOZINATOR's Avatar
El Dorado Hills, Calif
Joined Mar 2005
Wally,
Do you plan on making it yourself or store bought? Do you want the drive line at 0 degrees or ? What size prop and what type of boat.... a picture if you can with the length and width would help.The location of the rudder and skeg will also help. Are there plans to follow or recommendations?
You can go with a straight shaft or a flex shaft.
I know.... you wanted your question answered There are as many ways to make a stuffing tube as there are boats. Let us help find what is best for your application (budget)
jim
BOZINATOR is offline Find More Posts by BOZINATOR
Old Oct 13, 2009, 04:23 PM
towboatjoe is offline
Find More Posts by towboatjoe
River Rat
towboatjoe's Avatar
Flatwoods, KY
Joined Feb 2006
Here's how I make mine.
towboatjoe is offline Find More Posts by towboatjoe
Old Oct 13, 2009, 07:06 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
You might want to take a look at the MACK water tight stuffing boxes. Never need oiling once installed in the boat. www.mackproductsrc.com
frankg is offline Find More Posts by frankg
Old Oct 13, 2009, 07:48 PM
River Rat
towboatjoe's Avatar
Flatwoods, KY
Joined Feb 2006
I use axle grease in mine. I only add some once a year.
Old Oct 13, 2009, 07:52 PM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Umi's 'How to'..
http://www.rcgroups.com/forums/showp...2&postcount=11
toesup is offline Find More Posts by toesup
Old Oct 13, 2009, 09:02 PM
A-37 is online now
Find More Posts by A-37
A-37's Avatar
Cortland OH
Joined Dec 2007
Another Recommendation for 3/16" OD Prop Shafts
Buy a 4' length of 3/8" OD brass tubing from McMaster-Carr. The ID is a little less than 5/16". This will make a few stuffing boxes.
Get some Oilite bearings from your local bearing supply store. 5/16" OD x 3/16" ID.
Cut the tube to the desired length and silver-solder a grease tube. You could probably use regular solder but a silver-soldered joint will never break.
With a 5/16" drill, bore each end of the tube about 1/8" deep. This is slightly oversize for the Oilite bearing but gives you a starter hole.
Put the bearing in the tube, hold a block of hardwood over the bearing, and pound the bearing in.
If you forgot the grease tube and have already installed the Oilite bearings, you might see oil oozing from the bearing when silver-soldering. Don't ask how I know.
A-37 is online now Find More Posts by A-37
Old Oct 14, 2009, 02:16 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Robbe Model sport and Graupner both have shafts and tubes already set up with bushings and stainless shafts. The problem I have with 3/16 is there no good scale props for 3/16, but Rivibo, Raboesch, Radstock, and prop shop all make scale props for 4 & 5 mm shafts.
Right now only 2 of my 103 running boats have 3/16. One was built in 1955 the other is a Warehouse hobbies gas boat.
GILL RC is offline Find More Posts by GILL RC
Old Oct 15, 2009, 09:43 PM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
I have propshop scale props on 3/16 shaft . I got them from Harbor models .
jmolwitz is offline Find More Posts by jmolwitz
Old Oct 15, 2009, 11:48 PM
ZZ56 is offline
Find More Posts by ZZ56
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
Raboesch makes imperial versions of all their props.
ZZ56 is offline Find More Posts by ZZ56
Old Oct 16, 2009, 07:22 AM
fgroza is offline
Find More Posts by fgroza
USA, OH, cambridge
Joined Sep 2001
I believe that 5mm will thread onto 3/16" or 10-32 thread.
Frank
fgroza is offline Find More Posts by fgroza
Old Oct 16, 2009, 08:30 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
5mm will go on a 10-32 (3/16) thread. 10-32 WILL NOT go on a 5mm.
Old May 17, 2012, 05:54 PM
Fishy Hunter is offline
Find More Posts by Fishy Hunter
Fishy Hunter's Avatar
Joined Jan 2010
Octura Bushings
How do you keep the Octura Bushings in place in the brass stuffing tube (solder)?
Is the Octura bushing flush with the tube or does it stick out a bit?
I've made a stuffing box before using smaller brass tubes as bushing but I'm going to use Stainless steel shafts this time around.
I'm making two stuffing box for the Lindberg Fisherman.
Thanks!!
Fishy Hunter is offline Find More Posts by Fishy Hunter
Help! Stuffing box problem....! killick Scale Boats 9 Aug 17, 2006 10:26 PM
Discussion What grease in stuffing box? ABS painting? misfitsailor Scale Boats 8 Jul 08, 2006 09:12 AM
Question Graupner Shafts and Stuffing Box Questions hotjava Scale Boats 4 Apr 29, 2006 10:37 AM
Stuffing box and engine question C Thrower Scale Boats 4 Nov 06, 2005 01:28 AM
Question Grease for stuffing box??? Brutusjm Dock Talk 4 Jul 22, 2004 08:10 AM
