Old Apr 28, 2009, 05:45 AM
dsman is offline
Find More Posts by dsman
More like crunchman....
dsman's Avatar
United Kingdom, Cheshire East
Joined Mar 2007
Question
Wingbolt crimping "cups"
Help please!
We're all familiar with the recessed 3-dimensional washer "cups" (I apologise for not knowing their proper description) fitted to moulded wings, enabling the wingbolt/s to be crimped up sufficiently & distribute the load/protect the underlying glass/carbon structure.
Does anyone know a source?
I have a carbon Destiny wing which lacks them (all my previous Dessies had them fitted), and oddly - given the general quality of construction - my carbon Bird wing also lacks them (perhaps explains why the well-bolted wing shifted forward slightly & cracked the forward lip on the fuz during a mild impact into soft ground: that lip has now been filed off!).
I'm based in UK.
dsman is offline Find More Posts by dsman
Old Apr 28, 2009, 08:03 AM
dcairns is offline
Find More Posts by dcairns
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
Do you mean a Blind Nut?
dcairns is offline Find More Posts by dcairns
Old Apr 28, 2009, 08:34 AM
slopemeno is offline
Find More Posts by slopemeno
more casual than stylish....
slopemeno's Avatar
Joined Jan 2003
Screw cups? More properly- "escutheons"?
slopemeno is offline Find More Posts by slopemeno
Old Apr 28, 2009, 08:47 AM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
Tinnerman washers?
Nauga,
and his $15 bolts
nauga is offline Find More Posts by nauga
Old Apr 28, 2009, 04:03 PM
dsman is offline
dsman's Avatar
Joined Mar 2007
Thanks, guys, for your contributions; though none so far appears to identify the little rascals.
Slopemeno - "escutheon/escutcheon" could be it, but a Google search suggests not.
dcairns - the "blind nut" would certainly do a decent job, but it isn't the receptacle found in most mouldie wings, which are cup shaped with sides almost reaching the wing surface.
nauga - "Tinnerman" washers, ditto above remarks on the blind nut.
Anyone able to identify them?
They must have a name & there must be a source.
Old Apr 28, 2009, 04:35 PM
mr_editor is offline
Find More Posts by mr_editor
Biting ankles since '53
No Pants Island
Joined Feb 2007
Plain metal washers sunk at the bottom of my Bird60 wings. Not cup washers though. And don't worry, no matter what you do that lip on the Bird fix goes on a heavy arrival.
mr_editor is offline Find More Posts by mr_editor
Old Apr 28, 2009, 05:21 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Do you mean a washer that is quite thick with a counter sunk hole in the middle? Also machined into a domed profile? If so, don't know the name but they are occasionally used in the motorsport world to fasten body panels down. Try aerospace fastener suppliers or do you know anyone with a lathe?
S
PS last time I saw them was on a Group C Toyota so it's possible they had them machined 'cos their budget was 'sufficient'!
Shedofdread is offline Find More Posts by Shedofdread
Old Apr 28, 2009, 05:32 PM
quigley257 is offline
Find More Posts by quigley257
Say when.....
quigley257's Avatar
United States, MO, Hillsboro
Joined Sep 2005
Possibly Google "finishing washer"...?
--quigley
quigley257 is offline Find More Posts by quigley257
Old Apr 28, 2009, 05:49 PM
Derbyshire, UK
Joined Aug 2008
--quigley
The ones I had mind had a much larger outside diameter in relation to the hole through the middle and much flatter dome profile.
S
Old Apr 28, 2009, 05:52 PM
n-tropic is offline
Find More Posts by n-tropic
Put in all the lead
n-tropic's Avatar
Devon, UK
Joined Dec 2003
Are these what you're looking for Graham? Sorry had a helluva job trying to get a sensible picture of them with my cheap camera in poor light conditions.
Tim Avago put them in my carbon Sniper. I don't know what they are or where he got them from but he works for a metal fabricating / engineering company so maybe from there. I need to get some too but I won't get to talk to him for a couple of days. I suggest you e-mail him through this forum as he's not on here much at the moment. Otherwise I'll ask him on Thursday.
Steve
n-tropic is offline Find More Posts by n-tropic
Old Apr 28, 2009, 06:34 PM
dsman is offline
dsman's Avatar
Joined Mar 2007
Thanks for that Steve - those flush units would appear to do the necessary & could well be an adequate substitute if I can't locate any of the recessed cup variety.
(BTW, Jools & I had a great 3 days in S.Wales, warm & sunny with rather more wind than forecast: Skirrid first day, Mickeys the second & Black Hill the third. Still to sample PYF)
Old Apr 28, 2009, 08:08 PM
dcairns is offline
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
Cone Washer?
Old Apr 28, 2009, 08:13 PM
slopemeno's Avatar
Joined Jan 2003
I'd probably buy a brake line flaring tool from Kragen and make my own. I did get something similar from Orchard Supply called "compression inserts" (pn#9061045). They are made from brass and flared, so you'd end up with the equivalent of a countersunk area when you were done.
Old Apr 28, 2009, 09:49 PM
samotage is offline
Find More Posts by samotage
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
I usually just epoxy a normal "nut" with flocs to hold the thing in place.
samotage is offline Find More Posts by samotage
Old Apr 29, 2009, 01:31 AM
checkenbach is offline
Find More Posts by checkenbach
H.A.L. 9000
checkenbach's Avatar
Benicia Ca. USA
Joined Jan 2001
I call them wing bolt pylons.(He's talking about the piece that goes in the wing that the bolt cinches down on). Get some thick wall alumin(i)um tubing and get out the dremel, and epoxy and get to work.
checkenbach is offline Find More Posts by checkenbach
