Old Aug 22, 2013, 01:42 PM
Atleast It's in one piece
United Kingdom, North Weald Bassett
Joined Nov 2008
A Couple of Multifun Questions
Hi all
I bought a Telink Multifun and before you laugh it's the only VPTR'ish glider I could afford here in blighty.
I'm going to cover it with solar film/trim to try and make it a bit more slippery and I've moved the wings back 15mm hoping that will help with the tail heavy problem.
I'm also going to cut the ailerons off and make some stiffer ones and centre hinge them or I might stiffen the originals to keep some decorations.
What I would like to know is, someone mentioned fitting a ballast tube to enable ballasting so it could fly in a wider range of wind conditions, any ideas on how much ballast required?
Plus it looks as if the CofG may be bang on the wing joining wire so if only a small amount of extra weight is needed could I just fit a longer piano wire joiner, I realise this puts the weight in the wings and I'm not sure if that would affect the flying performance.
Arcright
Arcright is offline Find More Posts by Arcright
Old Aug 22, 2013, 03:33 PM
Tobias (aka glider hangaround)
Fluffracka's Avatar
Stockholm, Sweden
Joined Apr 2008
Ive modded mine pretty much to make it flyable and to get to live up to its name.
Here is the thread with all the info. Its a fun plane when its "right"...
http://www.rcgroups.com/forums/showthread.php?t=1421638
Fluffracka is offline Find More Posts by Fluffracka
Old Aug 22, 2013, 03:59 PM
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
Wot Fluffracka sez
I sold mine on before his modding info - uncovered, it only started to come alive with 6oz lead ballast on the CofG - and even then, it flew nothing like his version
try to get hold of some laminating film for the wings rather than Solarfilm - will make them much stiffer as well as smoother
Phil.
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Aug 22, 2013, 08:02 PM
Feeling FrSky
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
+1 on the laminating film suggestion. In addition to Fluffracka's build, I recall that Big Gas made a pretty successful version. He used some custom wing cores with a better airfoil (I think one of the TP series) and wider span (I believe around 60") and the plane flew fine (I saw it in person but did not personally fly it). The design has potential, but needs some kitbashing to achieve it. Have fun!
Steve
surfimp is offline Find More Posts by surfimp
Old Aug 23, 2013, 02:32 AM
Joined Nov 2008
Hi Guys
Fluffracka thatís some pretty extensive modding there lots of good ideas so lots to think about.
I did try to find some laminating film but it appears that I would have to buy a large amount just to cover one model so solar film was the next best option.
My long term plan is to get some other wing cores cut for it, if I can get it to fly reasonable well first.
I'm going to try flying along the tidal sea defence walls, every time I'm there a stiff breeze is hitting them square on or so it appears.
Thanks for all the suggestions
Arcright
Old Aug 23, 2013, 08:04 AM
Phil.T-tailer
Devon, UK
Joined Jun 2003
I've heard that some folks use laminating sheets/pouches from office supplies companies - A3 size might work - not used the stuff myself though
Soaring sea walls / dunes is great fun - but the Multifun may struggle, it needs good lift - DLG or Alula would work better (maybe a Weasel if you can get hold of one). For Kent, the cliffs at Beltinge / Reculver work well, but lots of paragliders.
Phil.
Old Aug 23, 2013, 01:54 PM
Fluffracka's Avatar
Stockholm, Sweden
Joined Apr 2008
Ive used A4 pouches that I split and overlapped and it works like a charm, done that on several planes...
Old Aug 23, 2013, 04:58 PM
Joined Nov 2008
Hi Guys
I'll look into the laminating pouches may be away around the problem.
Phill what you say about the sea walls etc is something I thought may be a problem but I thought I would just have to suck it and see, if it all goes horribly wrong I can chop the nose off and fit a motor to it.I did consider a flying wing but I remember having one before and finding it wasn't my thing.
I'm still. going to try and make it as slippery as possible and light, I've got about five weeks to build it maiden it and then I have a week in North Yorkshire followed by a week in Scotland
Thanks for the continued input
Arcright
Old Aug 24, 2013, 02:53 AM
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Arcright, Mark Abbotts on the RCMF UK forum sells small amounts of laminating film - PM him from here...
http://www.rcmf.co.uk/4um/index.php?...profile;u=8528
MattyB is offline Find More Posts by MattyB
Latest blog entry: EFX Racer
Old Aug 24, 2013, 07:48 AM
Joined Nov 2008
Thanks Matt
I'll give him a shout,any suggestions on thickness?
Arcright
Old Aug 24, 2013, 04:13 PM
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
I don't think there is any benifit in using the very lightest stuff on a Multifun, so try the next grade up - I think that's 3mil. Abbo will happily supply you with a few metres of each for a very reasonable price though, so hedge your bets and grab a selection (you can even use different thicknesses on different areas if you want).
Old Aug 25, 2013, 03:27 AM
Joined Nov 2008
Thanks that makes sense thicker film in the areas that might be subject to more abuse. Can you tell me if this film shrinks much under heat I'm wondering what it's like on compound curves?
Arcright
Old Aug 25, 2013, 06:45 PM
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
Shrinkage is very low to zero; you generally have to pleat it around compound curves, though I've never used the thinnest 1.7mil which could I suppose be different.
Lots more info available if you search on new stuff or laminating film; this thread has a video too...
Old Aug 25, 2013, 10:23 PM
Carpe Cerevisi
Buenperro's Avatar
United States, CA, Mission Viejo
Joined Nov 2010
I bought a Multifun a while back and covered the wings and fuse with 3mil CP lam film and the tail feathers with the 1.7. The total weight was under 17 oz. I kept it pretty much stock other than that.
I know everyone wants to turn it into somethiong else but I kinda like it the way it is. I have fun with it and other than the inverted preformance it flies ok. It is what it is!
Heres a short video of my trip to the local slope today. I'm not the greatest pilot so I can only imagine what it would do in the hands of an expert...
Rob
Multifun slope soaring (2 min 26 sec)
Buenperro is offline Find More Posts by Buenperro
Old Aug 25, 2013, 10:48 PM
Dick J's Avatar
United States, CA, Lake Forest
Joined Jun 2008
Video came out really nice Rob !! Great flying and sorry but it looked better in person he he
Dick J is online now Find More Posts by Dick J
Question Just purchased a S33, have a couple questions... ianoble Coaxial Helicopters 5 Jan 10, 2014 12:54 AM
Discussion a couple of questions Willj Scale Boats 6 Apr 21, 2013 06:59 PM
Question Just purchased a S33, have a couple questions... ianoble Beginner Training Area (Heli-Electric) 2 Apr 18, 2013 12:54 AM
Discussion New to FPV guy with a couple of questions. paul45120 FPV Talk 0 Mar 29, 2013 09:27 PM
Video Multifun+Multifun = a lot of fun! Two Multifuns (Telink) at the slope derfnam01 Sailplane Talk 0 Jul 19, 2012 05:53 PM
