Old Apr 25, 2013, 09:53 PM
United States, IL, Chicago
Joined Nov 2007
Simple, Bright Lights
I'm new to lighting up a plane, so maybe this is old news. But I found some awesomely bright LEDs that can be hooked directly to the flight battery. The white LEDs draw about 100 mA at 4V, the green draws about 60 mA. Only the red needs a series resistor (10 ohms), which I just soldered into the wire, and it draws about 100 mA. Hard to tell how very bright they are from the picture, but the H-stab is being lit from underneath.
Being able to connect directly to the balance port on the battery simplifies things a lot. I put each set (front white and green, rear white, and red) each on a different cell of the 3S flight battery. Of course, they don't flash.
Here's the links. I got the widest angle, highest brighness ones. And the company is rock solid. I've ordered many times from them for other purposes.
http://www.theledlight.com/5mmcoloredleds.html
http://www.theledlight.com/5mmwhleds.html
Neko is offline Find More Posts by Neko
Old Apr 26, 2013, 06:56 AM
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
From the datasheets these are standard diodes with 30mA Imax and 100mA if you pulse them with 1:10. So life expectancy should be rather low for your setup.
Direct connection is seldom a good idea.
RK
rkopka is offline Find More Posts by rkopka
Discussion A simple, inexpensive lighting alternative for small RC planes Stingray8854 Beginner Training Area (Aircraft-Electric) 25 Feb 02, 2013 05:46 PM
Discussion Simple, bright and cheap accent lights Bad Karma Electric Warbirds 1 May 31, 2010 09:21 PM
Discussion Bright lights & havochelis minster9 Micro Ready-to-Fly 1 Dec 29, 2007 12:25 AM
For Sale Bright PURPLE Led's,& light cannons. The Judge Aircraft - General - Miscellaneous (FS/W) 13 Feb 26, 2007 09:35 PM
Lighting, good price if bright enough rparigoris Electric Plane Talk 0 Mar 03, 2003 11:53 AM
