Old Feb 01, 2013, 08:51 PM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
Ah crap. You're right I switched the appropriate Kv ranges in my head while I was writing my first post. Doh! Yeah it doesn't work out quite like I wanted to since my argument depended on the opposite being true.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Feb 09, 2013, 07:18 PM
Joined Apr 2007
Originally Posted by Bruce Abbott View Post
Are these them?
Turnigy Aerodrive SK3 - 2822-1275
Turnigy 2730 Brushless Motor 1500kv
The 2730-1500Kv is a little smaller, so you might think it would be less powerful. However according to Drive Calc the SK3-2822-1275 is less efficient and wastes more power, so it may not be any better. What the SK2822 does gain is static thrust, because its lower Kv enables it to swing a larger prop without drawing more power.
Yes those are the motors. FlyBrushless tested both.
2730-1500
2822-1275
Thanks everyone for all the breakdown of information. I need to keep reading it another 40 times before i really get it. But thanks for the time and effort it takes to write all of that.
The goal of this plane is to be extra super light. Motor weight becomes significant. With mount and prop adapter the 2730-1500 is about 8 grams lighter. Its also more efficient as Bruce pointed out.
But this plane is more of an experiment 3D-ish type of plane. So should i automatically pick the 2822-1275 for more thrust at less amps?
I bought both motors over a year ago so they are just sitting here. I wonder if better options are now available. They are both max 8 amps. I have a plush 12 amp ESC for them. Lots of different props to try out but the 8/4 will work well according to flyBrushless info. I also bought several slow fly GWS like the 8/4.3 but i recently read they suck.
wopachop is offline Find More Posts by wopachop
Can watts be converted to thrust? Xnaron Power Systems 36 Aug 14, 2004 02:32 PM
Thrust in Vasa/65 comp. to MF480 at 150 Watts? Doc Dyer Electric Ducted Fan Jet Talk 9 Dec 13, 2002 10:16 AM
relation between duct/thrust/watts bgijsber Electric Ducted Fan Jet Talk 10 Sep 18, 2002 06:30 PM
watt per poundvs actual thrust, amp...???? Magna Electric Plane Talk 6 Apr 21, 2002 07:50 PM
Thrust vs watts crashnburn Power Systems 8 Dec 23, 2001 11:01 AM
