Old Nov 04, 2012, 01:53 PM
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Can airplanes be stored on the nose?
Is storing an airplane with the weight on the nose likely to damage the engine, or anything else?
grosbeak is offline Find More Posts by grosbeak
Old Nov 04, 2012, 03:24 PM
Sverige, Jönköpings Län, Aneby
Joined Aug 2005
Simple answer: No. as long as you dont bang them to the floor ones a week.. some of my friends hang there modells in the propp on a hook in the roof, tail down.
Put a rag or paper under the engine so the dripp dont get on the floor.
Guzzten is online now Find More Posts by Guzzten
Old Nov 04, 2012, 04:45 PM
Fla.
Joined Apr 2005
I HANG mine both ways so that I use max space on the walls, I've done it for years ~~ no problems. I do agree about NOT standing a plane on it's nose . ENJOY !!! RED
redh is online now Find More Posts by redh
Old Nov 05, 2012, 02:49 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Only problem with storing on their nose is the fuel lines can stiffen up and point down due to gravity.
tailskid2 is offline Find More Posts by tailskid2
Old Nov 07, 2012, 11:20 AM
Roselle,New Jersey 07203
Standing planes on their nose
It is okay, but be careful of this... Make sure you have absolutely no fuel in the tank..
Here is what happened to me. My copper tubes just behind the stopper corroded . Result no pressure line. Result, only half of the feed line inplace so the fuel just rotated in the tank .
Couldn't understand why the plane started but when it went into a climb .. dead stick!!!!
Lesson learned - empty the tank, disconnect all lines...
Good luck
LJR
ljr6282 is offline Find More Posts by ljr6282
Old Nov 07, 2012, 12:23 PM
United States, OR, Canby
Joined Aug 2011
I had a plane on it's nose for a while and the clunk fell to the front of the tank, had to shake the plane to get it to the back again.
600Bob is online now Find More Posts by 600Bob
Old Nov 07, 2012, 10:30 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Except for shaking the airplane some to ensure the fuel line goes to the rear of the fuel tank. it is no problem putting the airplane up against a wall or something nose down. It doesn't hurt anything. I have done it for many many years without any problems. Actually for inverted engines it helps keep oil from pooling onto the glow plug too.
earlwb is offline Find More Posts by earlwb
Latest blog entry: My new Gaui X5 Rc Helicopter
Old Nov 08, 2012, 08:41 AM
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
I should mention that of the three planes I need to store, one is glow and two are gas.
Old Nov 08, 2012, 09:15 AM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I also store my planes nose down. The only bad thing is the seals on the front bearing of my Enya 4C are bad so all the excess oil runs out the front of the engine Other than that, I've had no issues with nose down.
kenh3497 is online now Find More Posts by kenh3497
Old Nov 08, 2012, 09:56 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Those gas engine tanks will have to have their pluming redone.
Old Nov 13, 2012, 12:30 PM
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
I was hanging the wheels over a curtain rod on my PZ Corsair, now it rolls like it has 2 square wheels. oops
FloridaFlyBob is online now Find More Posts by FloridaFlyBob
Question Can this motor be used in an airplane? GoodStuff Engines 15 Oct 17, 2012 04:40 PM
Wanted Looking for a foam airplane that is BNF and can be shipped XtremeWingRC Aircraft - Sailplanes (FS/W) 0 Jul 31, 2012 01:10 AM
Discussion Can "IT" be done... configure Forward and Reverse on a hobbyking brushed ESC fly_right Electric Power Cars 2 Apr 07, 2012 07:38 AM
Help! Can the eflite eflrg110 gyro be used on airplanes? Redhood Electric Warbirds 0 Mar 16, 2012 07:31 PM
Question Can I be put on another users ignore? ctrout Site Suggestions / Complaints 4 Feb 28, 2012 07:56 PM
