Old Feb 20, 2012, 11:42 AM
Mauritius
Joined Jan 2007
20 A brushed ESC
Hi,
I have purchased a 20 A brushed ESC.
Will my stock motor RS-540 SSH burn the brushed ESC.
I don't know the no of Turn of the motor. My setup is an Atlantio 059.
Any advices please. Thank you.
SEALORD is offline Find More Posts by SEALORD
Old Feb 20, 2012, 12:31 PM
Blackpool, Lancs
Joined Feb 2006
Since the ESC is rated electrically foe Amps, you need to know the Amp draw of the motor. Best way is to run the motor, loaded, direct off the battery and measure it with your meter, which is an essential tool for checking circuits and whether or not you have volts in the battery.
Without a meter, get a selection of Auto fuses, start off with a low value, test the motor under load, see if the fuse blows, go up a value if it does until you dont blow the fuse. If that is below the ESC rating, you are good to go, if not, a bigger ESC is needed.
mfr02 is offline Find More Posts by mfr02
Old Feb 20, 2012, 12:47 PM
Mauritius
Joined Jan 2007
Im running a 7.2V battery.
Thank you very much, this look a good idea. The fuse will be an excellent indicator.
I would like to stick to brushed for some experiences.
Old Feb 20, 2012, 03:33 PM
Blackpool, Lancs
Joined Feb 2006
The meter does work better though......
It is a good idea to have the power fused, the fuse should be fitted between the battery and ESC, conventionally in the positive (red) power lead.
Old Feb 20, 2012, 04:26 PM
Stilwell Shipyard
lslewis's Avatar
United States, FL, Cape Coral
Joined Nov 2003
Purchasing a meter is almost a mandatory expense. It will serve you for years. The Turnigy watt meter will tell you the volts, amps and watts for only $24.
lslewis is offline Find More Posts by lslewis
Old Feb 21, 2012, 01:38 AM
Mauritius
Joined Jan 2007
Thank you again.
Lots of useful advices. Will work it out as proposed.
Sold E-Flite 20 amp Brushed ESC-$20.00 shipped Olias Aircraft - Electric - Power Systems (FS/W) 1 Oct 01, 2011 11:54 AM
Sold E-Flite 20 amp Brushed ESC-$20.00 shipped Olias Aircraft - General - Radio Equipment (FS/W) 1 Sep 26, 2011 09:31 AM
Found in need of 2 20 amp brushed esc's dr rc Aircraft - Electric - Airplanes (FS/W) 8 Apr 18, 2011 12:50 PM
Sold castle pixie 20 brushed esc captainpitts Aircraft - Electric - Power Systems (FS/W) 3 Apr 01, 2011 01:54 PM
For Sale various brushed ESC 60A to 10A $20 - $10 John Kim Aircraft - Electric - Power Systems (FS/W) 0 Mar 19, 2011 11:39 PM
