Old Oct 15, 2001, 10:49 PM
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
4.5x3 pusher prop source
I am scratchbuilding a 36" slowflyer with a friend, using a graupner 6v speed 280 (direct drive) as a pusher. I am having trouble finding a prop to go with this, however. Motocalc seems to favor a 4.5x3... 4.5x 2.75 and 4.75x 3 , and 5x 3.5 seem ok, but not as efficient.
anyone got a source for a prop that will work? anyone have pitch/size info on the e-gull pusher prop or the firebird prop, or for that matter, wingo/soarstar/etc? it needs to have a 2mm mounting hole, or be able to fit on a 2mm prop adapter...
thanks!
opualuan is offline Find More Posts by opualuan
Old Oct 16, 2001, 07:19 AM
Thessaloniki, Greece
Joined Mar 2001
Graupner has a direct drive 12x6 cm folding prop in pusher configuration for speed 280 motors: item # 1335.12.6 (L).
Alternative you can use a Paul Gunther push on prop.
good luck
pnikifor is offline Find More Posts by pnikifor
Old Oct 16, 2001, 02:40 PM
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
ok, i will simulate the graupner prop, closest I've seen. I went to the graupner site, and did not see the model with the (L) designation. where did you see this model? I guess I'll call graupner up...
I'd prefer folding, plus I don't think the gunther is the right size, slightly too big.
Old Oct 16, 2001, 09:23 PM
Walled Lake, MI, USA
Joined Feb 2000
See first prop at the top of the lefthand column:
http://www.hobby-lobby.com/camfold.htm
Dave Hederich is offline Find More Posts by Dave Hederich
Old Oct 16, 2001, 10:47 PM
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
I am using a thin airfoil and direct drive speed 280, and the graupner prop just doesn't have enough pitch... it has to be closer to 4.5x3... simulation too far away from this prop and performance suffers big time.
Old Oct 17, 2001, 08:29 AM
Joined Feb 2000
If you prefer folding, there simply are not many options in your size range. Simulations are OK to a point, but field testing beats simulation and bench testing every time. This particular Graupner folder is the only one in that size range that I've seen which is designed for a direct drive Speed 280 and its 2mm shaft. If it were me, I'd buy one for $12 and see how it works. They have them at my LHS for the same price as Hobby Lobby. If it didn't work on this particular aircraft, I'd stash it away for a future DD S280 application.
Old Oct 17, 2001, 09:46 AM
Joined Mar 2001
look at http://gm-racing.de/graupner/neuheit...tschrauben.pdf
or manual go to
http://www.graupner.de in "produkte" then press
"Download der Neuheiten 2001 als .pdf Dateien" then open "Luftschrauben 852kB" pdf archive. There it is in the first page, the folding - pusher speed 280 prop (for Graupner Tipsy I think) side by side with a Gunther. Text in plain German { : ) don't know either but specifications are easy to understand}
regards
4 blade folding pusher prop mount mitchamus Power Systems 0 Oct 20, 2004 08:38 PM
Question 4.5" pusher prop flies off inflight greyhound Electric Plane Talk 3 Dec 01, 2003 03:21 PM
aeronaut prop source? dezflyer Electric Plane Talk 2 Jun 18, 2001 06:54 PM
pusher prop as a tractor prop ? Al P Power Systems 2 Jun 16, 2001 01:09 AM
Using pusher prop glovesave39 Beginner Training Area (Aircraft-Electric) 3 May 03, 2001 04:05 PM
