Old Mar 25, 2010, 10:34 AM
outsider787's Avatar
Canada, ON, Toronto
Joined Dec 2007
Question
Increasing flight time with larger battery?
For a given multi-rotor craft, what's the best way to extend flight time?
It seems that the average flight time for most multi-rotor guys is 10-15min.
So short of loosing weight (which beyond a certain point becomes in-practical), and getting more efficient motors, what's the effect of using a larger capacity battery?
Does it scale linearly? Exponentially?
Any studies done on this?
outsider787 is offline Find More Posts by outsider787
Old Mar 25, 2010, 10:58 AM
The Drones are Coming!!!
cyborgcnc's Avatar
New York, NY
Joined Feb 2010
Well do a search here, and on google, and you will find lots of good information on battery size vs flight time.
Basically, given a certain set of motors, and speed controllers, at a given load, and a given Prop size, they will draw a given current. Knowing this, you can then calculate the size of battery needed, given an amount of time you need to fly.
There are many well defined formulas that give you this, as well as power meters, that will help one in determining these values, with their equipment.
Everything is a trade off...since more time, requires larger capacity batteries, and those will weigh more etc etc.
cyborgcnc is offline Find More Posts by cyborgcnc
Old Mar 25, 2010, 11:06 AM
A man with too many toys
United States
Joined Feb 2001
When weight goes up the watts per Kg tend to stay about the same.
I have found that props due make a difference. When I went from an APC 10x4.7 to 10x3.8 I got more flight time so it pays to due some experimenting.
I have seen setups that hover at very low throttle level which can be below the motors maximum efficiency current. In that case a larger battery would give both a longer flight time and better efficiency. Again it pays to experiment. Every multi-rotor is different so some flight-testing is the best way to see what works best for what you want.
Also some of the new batteries are very heavy for their capacity so take a close look at that before you buy a new battery.
RC Man is online now Find More Posts by RC Man
Old May 30, 2010, 09:09 PM
rimshotcopter's Avatar
Joined Aug 2009
RC Man, what size was the Bell on the motors you were using in the above example?
Thank you.
rimshotcopter is offline Find More Posts by rimshotcopter
Old May 30, 2010, 11:13 PM
Joined Jun 2009
Here's a little empirical case study for a hexrotor I'm building. It was made by measuring current in tethered flight with ballast weight.
The battery assumed in this study is a 5000 mAh 4s1p Zippy pack, weight 475 g. With a single pack it gives me up to 24 minutes of hover time, with two I should get about 35 minutes (+11 minutes), with three packs it comes down to about 42 minutes (now only +7 minutes). Beyond this point it's no longer viable to add more batteries, because the motors have to run at RPMs so high that the power requirements skyrocket. The relationship is logarithmic then.
tori3 is offline Find More Posts by tori3
Discussion OPTIMUM BATTERY FOR EXCEED RC F-35 increased flight time ecfarr Foamy EDFs 2 Sep 08, 2009 01:48 AM
Discussion Increasing flight time and minimizing drift CaptJac Coaxial Helicopters 3 Apr 23, 2009 12:18 PM
Discussion Double flight time with a spare battery! arbilab Coaxial Helicopters 4 Jan 18, 2009 08:33 PM
Increasing flight time on a Hobbico SuperStar EP Select Plane AMarkIII Electric Plane Talk 2 May 18, 2005 08:48 PM
Flight Time With 1100 mAh Rx battery? screamin' eagle Slope 4 Jan 24, 2005 10:47 PM
