Old Jul 24, 2009, 11:15 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
New Product
Two EDO fan versions now in stock
OK guys I just got in a shipment of the other style 64mm EDF fan units. These have the inlet lip as a separate piece so it should cover all the 64mm EDF ARF and RTF applications out there today
One piece:
http://www.donsrc.com/cart/index.php...d&productId=74
Two piece:
http://www.donsrc.com/cart/index.php...d&productId=86
Don
The Don is online now Find More Posts by The Don
Old Aug 05, 2009, 10:36 PM
Got Another Prop?
WadesRC's Avatar
United States, VA, Hampton
Joined Aug 2006
Delete Post
WadesRC is offline Find More Posts by WadesRC
Old Mar 15, 2010, 02:23 PM
This is glue Strong Stuff
tofuti's Avatar
Palo Alto, CA
Joined Oct 2007
Don, for the 2 piece fan, do you have dimensions published anywhere? Specifically the length of the shroud minus the lip? The application I have in mind does not require the lip, but I need to see how much carving or filling I might need to do in order to drop it in.
tofuti is offline Find More Posts by tofuti
Old Mar 15, 2010, 10:17 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
33mm long
Old Jul 21, 2010, 11:33 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
New 64mm fan unit I am going to test out. Much stiffer rotor.
Don
Old Jul 22, 2010, 09:54 PM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Don
Any results?
Prof100 is online now Find More Posts by Prof100
Old Jul 22, 2010, 10:37 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Not yet, but this will be going into my Exceed RC Concept X
Don
Old Jul 23, 2010, 01:18 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Actually I can not say I did not test it at all. it does pull similar amps as the EDO fan does and I did a set for a guy with Wicked 4800s on 3S for a Max-Jet SR-71. The main reason I want to test it is for the wicked 4000 plus motors and possibly 4400 plus on 4S for higher power 64mm applications. The EDO type I fan has been working but I wish the rotor was a little bit stronger. This new fan unit is the same as the fan used in many of the Nitroplanes kits.
Benefits:
1) stiffer rotor for more watts (main objective)
2) no tabs need to be ground out to make standoff fit
3) rotor is keyed to adapter
Downside:
1) requires a LOT of ballast to dynamically balance they shake like crazy out of the box.
2) rotor adapter only has one set screw so will require loctite to secure properly for higher watts.
Don
Old Jul 23, 2010, 07:28 AM
Prof100's Avatar
Joined Jul 2007
Benefits:
Downside:
Don
Sounds like stiffer rotor should make more power but the tradoff is difficulty balancing and having to balance or risk exploding the fan. Plus, care must be used to secure the rotor adapter.
Bill
Old Jul 29, 2010, 09:33 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I tested the Wicked 4000 plus in the airfield 64mm fan and on 4S I get similar to the EDO 1 fan , I got about 42 amps and 620 watts with this unit.
Old Nov 14, 2010, 01:38 PM
awayne's Avatar
Pacifica,CA
Joined Oct 2006
Hi Don,
Will you be getting more EDO type 2's in soon? I see they're out of stock on your site.
Thanks!
andy
awayne is offline Find More Posts by awayne
Old Nov 14, 2010, 02:05 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I have them, website is updated.
Don
Old Nov 14, 2010, 02:27 PM
awayne's Avatar
Pacifica,CA
Joined Oct 2006
Very cool! I just ordered a 4000Kv and edo 2 balanced set up on your site. This is going in to hobby lobby's new f9f panther. Are you gonna hit the button on that one?? If so, I'll be looking forward to your review.
Thanks again!
andy
Old Nov 14, 2010, 02:39 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I am thinking about it. But the issue is the next few months will be snow so will not really be able to fly much now. Wish it was out about a month sooner, I may pick one up if they go on sale after Thanksgiving. Are you planning on running 4S?
Don
Atomic Force NOW in Stock at Tower Hobbies vkmaynard Electric Heli Talk 2 Apr 24, 2002 06:32 PM
Hornet 120 degree swashplate - NOW IN STOCK rcdude Electric Heli Talk 0 Mar 29, 2002 02:55 AM
New Coreless motor now in stock DNA Parkflyers 12 Jan 10, 2002 05:59 PM
Zapped 1300's now in stock Ralph Weaver Electric Plane Talk 9 Jul 17, 2001 09:12 AM
CP-1700SCR cells now in stock in US Ralph Weaver Electric Plane Talk 0 Jul 09, 2001 10:06 PM
