Old Feb 11, 2009, 05:17 PM
Joined May 2004
Gallery
EPP C-27J Spartan
Here is gallery of my epp C-27J Spartan transport aircraft
basic info :
Wingspan: 1500mm
Lenght: 1240mm
Weight: 1400g
4x A123 2300
2x DualSky Xmotor XM2830CA-10 , 3 blade GWS HD 9x5 (counter rotating)
rudder, elevator, ailerons, flaps, loading ramp and landing lights
epp is cutouts from http://www.rcfly.cz/RCFly%20eng.pdf
pictures will follow
Amper_CZ is offline Find More Posts by Amper_CZ
Old Feb 13, 2009, 04:12 AM
Joined May 2004
Preparation for first maiden
First maiden flight ended with little tragedy. There is problems with everything - center of gravity, too extended flaps, bad design of front wheel for grass surface.
Fortunately plane landed just with small damages (just on front wheel mount)
Old Mar 01, 2009, 07:41 PM
San Diego
Joined May 2008
hello. very nice plane. i was wondering how much thrust are you getting out of the motors each?
annihil8ted is offline Find More Posts by annihil8ted
Old Mar 02, 2009, 05:15 PM
farnboro flyer's Avatar
Farnborough, Hampshire, England.
Joined Jan 2002
Great subject!!............be good to hear of more?
Ian
farnboro flyer is offline Find More Posts by farnboro flyer
Old Mar 03, 2009, 11:42 AM
Joined May 2004
Current version
so, here is last batch of pictures from last year.
it is last version of Spartan with active landing lights, loading ramp and improved design with few panel lines ,decals and printed parts.
I will continue with video of loading ramp,more pictures and data. Stay tuned
Old Mar 03, 2009, 12:00 PM
Joined May 2004
Spartan in action
here is first Spartan video. It is from beginning of flying with Spartan so landings is not so good :-( Also I must take video with better camera then this one, but you can see few loops there.
C-27J Spartan (4 min 34 sec)
Old Mar 03, 2009, 01:32 PM
Joined May 2004
Loading ramp
here is landing ramp video :
ramp (0 min 47 sec)
This is first version, current version is much more rigid - servo holder is from balza instead of EPP and pushrod is 2 mm instead of 0.5mm wire.
I am waiting for Jeti Duplex R14 receiver and then I want add unlocking servo for load. Now you need lot of luck to do airdrop somewhere close to wanted place because load is sometimes stuck up between ramp doors and so.
With lock will be possible open ramp door and then release and drop load.
Old Nov 18, 2013, 03:49 AM
Czech Republic, Central Bohemian Region, Beroun
Joined Nov 2011
It is very sad- Start to the first flight with all these defects and expect that it will turn out well- It was Your first model of this category?
Herky36 is offline Find More Posts by Herky36
Old Nov 19, 2013, 04:36 AM
Joined May 2004
Yep, but it is long time ago and now I am much more experienced and Spartan is still in good shape.
Old Nov 19, 2013, 02:27 PM
Joined Nov 2011
So, thats are great news!!!
We prepare just a little bigger version XXL... 2000mm wing span ;o)
I am going to build C-27 Spartan/G-222 Monty CZ Foamies (Kits) 16 Jul 29, 2014 05:29 PM
Question Micro Blade EPP C Of G 109Mechanik 3D Flying 9 Aug 14, 2007 07:28 PM
Discussion blade epp c of g problem? franky31 3D Flying 6 Aug 12, 2007 04:20 PM
