Old Jun 07, 2008, 09:28 AM
piro-maniac........
GunnyGlow's Avatar
United States, CO, Aurora
Joined Dec 2007
Question
slimline pitts muffler/.46FX less power??
So I have been planning on running a slimline pitts on my OS 46. I did this and have noticed a decrease in RPM, throttle response....etc etc. Nothing really bad....it just doesn't have the punch it used to. Now..the question!
Does the addition of this new exhaust system decrease the pressure being fed to the tank from the nipple on the muffler?? I think so.....I"ve heard of pitts causing the engine to run lean b/c of this. And would this be causing this loss of power and such, that I describe?
PS...I did readjust both needles after installation...
GunnyGlow is offline Find More Posts by GunnyGlow
Old Jun 07, 2008, 10:27 AM
Wayne V's Avatar
London, Ontario, Canada
Joined Jan 2006
Most times the backpressure will be less with a pitts muffler, my friend had one on his magnum .46xls and we ended up plugging one of the holes to get the best performance.
Wayne V is offline Find More Posts by Wayne V
Old Jun 08, 2008, 05:52 PM
piro-maniac........
GunnyGlow's Avatar
Joined Dec 2007
yup....plugged a hole and it was much better.
Thanks Wayne!
Old Mar 19, 2014, 02:18 PM
Madison, MS
Joined Oct 2006
Did y'all experience the slimline Pitts making your fx run hotter? I did adjust my needle valves but it seemed to run hotter with the Pitts vs the stock muffler.
dpowellmeii is offline Find More Posts by dpowellmeii
Old Mar 20, 2014, 12:57 PM
DarZeelon's Avatar
Israel, Ramat HaSharon
Joined Nov 2003
Most Pitts type mufflers are detrimental to performance.
You are either victimized by too small a volume, or by too large an outlet cross-section.
In any case you get less power from your engine... unless you get a TurboJett...
Yes, it's expensive, but nothing's free in the real world.
DarZeelon is offline Find More Posts by DarZeelon
Old Mar 20, 2014, 07:11 PM
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
The size and shape of the exhaust influences a 2 stroke.
jeffie8696 is offline Find More Posts by jeffie8696
Old Mar 24, 2014, 12:46 AM
Madison, MS
Joined Oct 2006
Thanks fellas.
NIIP Slimline Pitts Muffler Fox 40 BBRC DPage Aircraft - Fuel - Airplanes (FS/W) 1 Nov 17, 2003 08:06 AM
Slimline Pitts Muffler OS 25 LA DPage Aircraft - Fuel - Airplanes (FS/W) 0 Nov 08, 2003 09:38 AM
Fox 40 Slimline Pitts Muffler DPage Aircraft - Fuel - Airplanes (FS/W) 0 Sep 21, 2003 08:25 PM
