Old Apr 27, 2005, 12:31 AM
FLY3OY
LuftAdler's Avatar
Virginia
Joined Aug 2003
Work begins on my F6F Hellcat
Finally started on my China Models F6F Hellcat which I purchased off E-bay back in December '04.
Cut out the wheel wells and servo aileron positions tonight.
LuftAdler is offline Find More Posts by LuftAdler
Old May 05, 2005, 11:50 AM
scott282's Avatar
Buffalo, MN
Joined Jan 2005
LuftAdler,
Any updates? How about some details too. Engine size, equipment used, mods made to it.
I've been thinking of adding this airplane to my fleet. This is a great looking airplane and look forward to hearing how it flys.
Scott.
scott282 is offline Find More Posts by scott282
Old Nov 29, 2005, 07:44 PM
FLY3OY
LuftAdler's Avatar
Virginia
Joined Aug 2003
OK, this time I think I am really going to finish the F6F. I have had this plane sitting in a box since last December, along with a brand new engine and servos. Had a false start in April, but I think it is finally time!
Today I installed the engine mount onto the firewall. Also assembled the engine. a Super Tigre .90 2-stroke.
Old Nov 30, 2005, 09:00 PM
FLY3OY
LuftAdler's Avatar
Virginia
Joined Aug 2003
Today’s work:
1. Installed the fuel tank. Used clear silicon to mount the tank as well as isolate it from engine vibration.
2. Attached the huge horizontal stab using 30min epoxy
3. Installed the rudder, elevator, and throttle servos. Using Futaba S3003 servos.
4. Painted the cockpit and wheel wells with zinc chromate
Old Dec 02, 2005, 10:32 PM
FLY3OY
LuftAdler's Avatar
Virginia
Joined Aug 2003
Today I attached the tail wheel, rudder, and horizontal stabs along with control horns. Did a few cockpit details and attached the canopy. Attached the throttle control rod and tested. Installed the wing servos, both Futaba S3003. Replaced the original S3003 elevator servo with a high torque Futaba S3010 servo. Also realized that my standard 4.8 volt RX battery is not going to work in such a large plane. Looking at purchasing a 6 volt 1500 Mah rx battery to give me the greatest torque on all servos and longer flight times.
Some notes on this China Model:
The tail wheel is attached to the rudder and is poorly designed. I am interested to see how long it will last. Very difficult to install because you must cut and bend the tail wheel rod after inserting it into the fuse.
Control rods as they are depicted in the instructions are also going to be a major problem. They catch on the internal fuse frame and must be bent in order to take pressure off the rod itself.
Old Dec 03, 2005, 01:41 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Nice work!
Kmot is offline Find More Posts by Kmot
Old Dec 04, 2005, 12:19 AM
In Massive Debt
Northampton Massachussetts
Joined Jun 2005
6.0v =useless
4.8v=best bet
If your only switching to 6.0 volts to get the extra torque, then your nto using the right servos. Your best bet is to stick with 4.8v and jsut get a larger capcity pack. 6.0 increases the chance of servo glitching.
blizzardwarrior7 is offline Find More Posts by blizzardwarrior7
Old Dec 04, 2005, 06:31 PM
FLY3OY
LuftAdler's Avatar
Virginia
Joined Aug 2003
Originally Posted by blizzardwarrior7
6.0v =useless
4.8v=best bet
So 4.8v is standard in giant scale planes?
Old Dec 04, 2005, 06:35 PM
FLY3OY
LuftAdler's Avatar
Virginia
Joined Aug 2003
Finished up a few more items before placing an order for additional parts and pieces I need to continue the build.
Got the rudder control rod installed and tested. Installed the cowl.
If the parts come in this week, I should be able to finish the wing this coming weekend and maybe get a engine break in and taxi test if lucky.
Old Dec 05, 2005, 01:15 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Well, you've certainly made up for lost time!
Old Dec 05, 2005, 04:37 PM
In Massive Debt
Joined Jun 2005
I use 4.8 v on all of my planes. On a plane such as this one, you definetly dont need really high torque servos anyway.
Old Dec 05, 2005, 07:45 PM
FLY3OY
LuftAdler's Avatar
Virginia
Joined Aug 2003
So this size plane is well within the limits of my Futaba 3003 servos?
Old Dec 05, 2005, 07:51 PM
FLY3OY
LuftAdler's Avatar
Virginia
Joined Aug 2003
Aircraft Specs:
Wingspan 70"
Length 53.5"
Engine: Super Tigre G-90 2-stroke
Weight: TBD
Servos: 6 (Elevator, rudder, flaps, ailerons, throttle, retracts)
Old Dec 05, 2005, 08:52 PM
In Massive Debt
Joined Jun 2005
0.23sec/60 deg @ 4.8V
44 oz-in @ 4.8V
Seems they should be fine IMO. None of the control surfaces are very big, so its not nessesary to have lots of torque, and since its not an aerobatic or 3D plane, you dont need extremely fast servos either.
Old Dec 09, 2005, 10:54 PM
williston fl
Joined Jun 2005
hellcat
whose retracts are you using?
rede2fly is offline Find More Posts by rede2fly
Help on my Molt Hellcat build Dave K Parkflyers 4 Sep 25, 2004 10:25 AM
Wobbly tailwheel on my Scorpio Hellcat nhorianopoulos Parkflyers 4 May 25, 2003 02:08 PM
Nice F/G 46"WS F6F-HELLCAT on E-Bay speedo Aircraft - Electric - Airplanes (FS/W) 2 Oct 02, 2002 12:28 AM
Why does Channel 60 not work on my plane? RPatrick Power Systems 8 Jun 17, 2002 02:03 AM
Will an Astro 25 work on my TF P-51? Ken Lapointe Electric Plane Talk 13 Oct 05, 2001 05:22 PM
