Old Mar 12, 2014, 03:26 PM
Joined Jun 2010
Help!
GMFC with USB
Hi all need a little help, I have newly installed GMFC Pro with the USB interface I am using the Hobby CNC board I am running Windows XP SP3 here is what happens when I go to the Zero Axis and try to run the motors they all run in one direction I turned off the Sync Axis and all the motors turn at the same speed in the same direction no matter which arrow I press I tried using FW4 with Mach 3 and was successful in getting my motors to run. My settings in Mach 3 was 4000 step Velocity was 35 and accel. was 9 I tried different settings in GMFC but am having no luck. Any sugestions
Pat
pjf610 is online now Find More Posts by pjf610
Question Charging 1S Li-Po with USB Charger and USB Power Bank Frogboy Batteries and Chargers 5 Jan 29, 2014 06:39 AM
Build Log S.E. 5a WW I fighter cut on cnc with GMFC kilop Foamies (Scratchbuilt) 7 Feb 02, 2010 06:49 PM
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 01:24 PM
Discussion GMFC compatible with Foamlinx board? jtprouty The Builders Workshop 9 Dec 08, 2009 03:20 AM
Discussion Need help with GMFC PRO BMtech Slope 2 Jul 26, 2009 11:31 PM
