Old Aug 06, 2013, 03:18 PM
Las Vegas, NV
Joined Jun 2007
Mini-Review
30cc Thunderbird..???
Received the 30cc Thunderbird...the kit came well warped..no breakage.
The instruction manual was a general manual covering all of the 30cc models...
this might be a problem for a first time builder...I did not have any problems assembling the model ..went together without any problems.
The model was designed for a 30cc motor..I installed a DLE20 (20cc motor), I was
a bit apprehensive putting a 20cc motor in..Well, let me tell you it flies very well with
a 20cc motor..it loops..cuban eights etc..have not tried 3D yet..but it was flown between i/2 to 3/4 throttle without any problems..quite fast...had no problems landing the model..slows up very well without stalling out...
Note: I am using DS821 servo's without any problems..the balance was right on
as I did not have to add any weight...If you want a good sport flying plane ..then I
can recommend this model...a steal at $180.00
Codimasta
AMA 11269
Codimasta is offline Find More Posts by Codimasta
Old Nov 13, 2013, 09:43 PM
Need a bigger runway
sandydr's Avatar
Dominican Republic, Puerto Plata, Cabarete
Joined Mar 2008
Hi Codimasta
Just wondering how this plane has been holding up for you. Any opinions on the quality of the hardware provided. Looking for a replacement for my demolished HK Sbach 30cc.
Thanks, Sandy
sandydr is offline Find More Posts by sandydr
Old Nov 16, 2013, 10:24 PM
Las Vegas, NV
Joined Jun 2007
Still flying it..as I said it was a steal for $180.00...no problems..hardware is pretty good..
They do not say this but you can run dual elevators..the cut outs are there...I think you will like it...should be a bomb with a 30 cc...mine flies great with a DLE 20...
Codimasta
AMA 11269
Old Nov 17, 2013, 06:26 AM
sandydr's Avatar
Joined Mar 2008
Thanks, I ended up going with a different option but will keep my eye on this as a next candidate! Regards, Sandy
Old Mar 04, 2014, 12:46 PM
Georgia
Dan mach's Avatar
United States, GA, Augusta
Joined Dec 2012
Codimasta,
You say yours was well warped, how bad?
I was going to order one today, but may not if they come warped.
Dan mach is online now Find More Posts by Dan mach
Old Mar 04, 2014, 12:48 PM
Georgia
Dan mach's Avatar
Joined Dec 2012
Anyone done an electric conversion on this?
Old Mar 06, 2014, 02:04 PM
Las Vegas, NV
Joined Jun 2007
Thunderbird
Originally Posted by Dan mach View Post
Codimasta,
That was a typo..error... WRAPPED NOT WARPED..
Still flying it..great plane..
Codimasta
Old Mar 07, 2014, 05:18 PM
Georgia
Dan mach's Avatar
Joined Dec 2012
Still using the same servos?
Did you put two on the elevator?
Old Mar 10, 2014, 10:56 PM
Las Vegas, NV
Joined Jun 2007
Thunderbird
I am still using single servo (821) on the elevator...It might be a good idea if you are doing a lot of 3D...
Codimasta
AMA 11269
Old Mar 11, 2014, 01:42 PM
Georgia
Dan mach's Avatar
Joined Dec 2012
My Thunderbird arrived today!
Double boxed. The exterior had some damage so I was hoping there wasn't any inside. Open up the box and no damage at all!
Everything was wrapped and taped in place. Inspected each part and the only
Discrepencie I could find ( and a small one at that) was the canopy had some discoloration from the c/a glue used in the fuselage, but not much.
I dry fit everything, and this thing is big, but light. Overall pretty solid and the covering is better than the e-***** and h*****9 kits I have purchased. The tail feathers are sheeted with balsa and covered in monokote. I received the aluminum spar tube which is very strong, not a carbon fiber one.
$237.00 with shipping and received it from CA in 7 days. Looks like an easy build. Can't wait to get it started. Have to finish my kitchen remodel first.
Build Log Red Wing Rc 30cc Mx2 best 30cc out there f22 parkflyer 3D / Fun Fly Fuel Planes 6 Nov 06, 2014 01:28 PM
Build Log Nitroplanes' Nitromodels 30cc Thunderbird saios 3D / Fun Fly Fuel Planes 2 Apr 06, 2013 11:36 AM
For Sale Peak 30cc Sbach and Aerobeez 30cc Sbach Waco Aircraft - Fuel - Airplanes (FS/W) 2 Jun 28, 2012 11:22 PM
Build Log New Slipstream aircraft. The MXS 30cc and the SBACH 342 30cc cryhavoc38 Glow to Electric Conversions 12 Feb 06, 2012 10:52 PM
Thunderbirds are go! (Thunderbird 2 that is....) bipeflyer Foamies (Kits) 15 Oct 24, 2002 09:19 PM
