Old May 05, 2013, 02:54 PM
Whisper Model Aircraft
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Xflr and gap TE
I've bugged Tom enough.... Now, it's time to bug you guys!
So, I want to gap the training edge of my airfoil .02"
I see the gap function, but I don't understand what % cord to use.
Also, when I export the dat files and change the cord how is that going to scale correctly?
Will
heliwill10 is offline Find More Posts by heliwill10
Old May 05, 2013, 08:58 PM
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I've just been out of pocket Will. I replaced the heat pump / AC in my house and shop this weekend.
I always set the TE thickness in XFLR to be 1 / chord*.3mm (.011") for DLGs. It could probably be a bit thicker for TD stuff.
The thought is that you want all of your stations to scale up to a .3mm TE thickness. If you have a 200mm chord for example, you would have a TE thickness of 1/200*.3 in XFLR. When you import it to Rhino it will be dimensionless as a point cloud and the airfoil will be 1mm long. Scaling it times 200 to make the chord correct will scale the TE to exactly .3mm.
Clear enough? I know I shared the equation before but I didn't explain it fully.
tom43004 is offline Find More Posts by tom43004
Old May 06, 2013, 07:20 AM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Yup, got it!
So, the calculation is entered into the "gap TE" do you use a 100% cord?
Old May 06, 2013, 02:44 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Ok, for the follow up on XFLR and TE Gap.
The math needs to be as follows.
Desired T.E. Gap/ Wing Cord * 100
I used the default blending distance
Will
Discussion Wing Ribs with only sheeting for TE??? Atomikbohm The Builders Workshop 7 Mar 30, 2013 12:23 AM
Discussion How to fill in gaps when strength is needed? rwpeek The Builders Workshop 9 Mar 21, 2013 10:52 PM
Question Should you seal your hinge gap? 3Daddict 3D Flying 26 Feb 23, 2013 12:50 AM
Discussion Gap seal and hinge tape Flying-Addict Slope 1 Feb 18, 2013 10:41 PM
Discussion Te'o Story Indiana_Geoff Life, The Universe, and Politics 2 Jan 20, 2013 09:39 AM
