Old Apr 17, 2013, 03:17 PM
wehan's Avatar
Joined Jan 2013
Yippee!
New gmade r1 kit on it way
Just hit go on a new gmade r1 kit along with the delrin skid, rcscrewz kit, savox high torque servo.. Next paycheck will be axial 2.2 8hole beadlock wheels in black and mickey Thompson ttc claws.
wehan is online now Find More Posts by wehan
Old May 07, 2013, 04:51 PM
Backyard_Basher's Avatar
United States, PA, Croydon
Joined May 2013
yeah or neah?
So....how is it?! I'm interested in getting one myself and was wondering what motor/battery type you are using and how the overall performance is.
Backyard_Basher is offline Find More Posts by Backyard_Basher
Old May 16, 2013, 12:34 AM
wehan's Avatar
Joined Jan 2013
Took it out last weekend and popped its cherry, I love it. Took it around a local jogging/dog walking park and had heads turning and people just watching in amazement. The tires suck and need to be replaced ASAP and some wheel weights are next after tires. I'm running a hoby people 2200mah 3s 20c with a mamba max pro and 55t axial motor.
Description:
Old May 16, 2013, 09:30 AM
Joined May 2013
Awesome! That's what I wanted to hear. I really love the look of the R1 & plan on making that or the RC4WD Bully my next rc.
Old May 16, 2013, 07:57 PM
wehan's Avatar
Joined Jan 2013
I'm running it both front and rear in the sprung position but I'm going to try the rear in to droop position as I hear it is more capable that way. Its shelved for now because I must have missed a driveshaft set screw while going over it with loctite and it spit it out all well $5 later and I'll have some axial pins that go all the way through the output shafts instead of the 2 on each side that only go about 1/4 the way in.
Oh yeah, I'm using the junfac hardened steel shafts.
Old May 18, 2013, 08:18 AM
Joined May 2013
I was wondering about those double grub screw shafts. Good idea switching to the axial screw shafts with a little bit of blue locktite. The full length pin should be a bid more durable too. Nice rig set up so far, its making me salivate!
Old May 19, 2013, 11:37 AM
wehan's Avatar
Joined Jan 2013
Got the axial pins last night, threads fit but the pin itself is larger so I had to drill out the output shafts/pinion shafts a little. I didn't have any metric drill bits but a 7/64 did the trick, the pins measure in at 2.42mm. I used the axial part #AXA0175.
Question Recommendation of Gmade R1 shocks???? phishintodd Rock Crawlers 0 Jan 27, 2013 05:12 PM
New Product Now stocking the GMade R1 Crawler M1A2 Commander Rock Crawlers 0 Jan 17, 2013 01:14 PM
Discussion Gmade R1 - Lipo instead of Nicd?? Help?? phishintodd Rock Crawlers 3 Jan 14, 2013 12:38 PM
Discussion Gmade R1 - Brushed or brushless? phishintodd Rock Crawlers 5 Jan 12, 2013 10:38 PM
Sold Gmade r1 rock crawler complete!!! jetfighter2008 Cars - Trucks and Parts (FS/W) 2 Mar 16, 2012 04:37 PM
