Old Apr 04, 2013, 10:46 AM
Mezmerizing...ain't it!
Robert N's Avatar
San Jose, California
Joined Jul 2007
Should I use a Digital Servo with Tricopter
I posted this question on the other forum here on RCGroups.com...not many responses, I think it should have been posted here.
My question: I am building the tricopter found at RCExplorer.se and plan on basic flying around and hopefully then learn some fancy 3D stuff. I know Metal Gears are a "must"...Is the Digital Servo worth the extra $$ investment?
Recommendations, suggestions and comments are always appreciated!
Robert N is offline Find More Posts by Robert N
Old Apr 05, 2013, 12:24 AM
Joined Feb 2013
Am too building a T-copter and am using Digital metal gear servo... much better than analog I would say...
VTOLkarthik is offline Find More Posts by VTOLkarthik
Old Apr 05, 2013, 12:32 AM
USA, WV, Moundsville
Joined Oct 2006
i use a hitec hs5065 digiatal metal gear for the "tail" on my LA Heli Y Ufo deffinately better holding and resolution than an analog servo
turbored21 is offline Find More Posts by turbored21
Old Apr 05, 2013, 05:59 AM
Out of helis, sanity returning
Tallahassee, FL
Joined Feb 2009
I used a Futaba 9650 on the tail of my tri, and it works really well.
It's probably not worth using a digital servo unless your flight controller can update it at faster than the 50hz that analog servos are updated at. My 9650 is updated at 330hz by the OP CC3D board I'm using. I don't have any real experience with other FCs, so I can't tell you about update rates for various boards.
2400RDR is offline Find More Posts by 2400RDR
Old Apr 05, 2013, 08:42 AM
Joined Feb 2013
My tri is using a cheap PowerUp analog metal gear servo with a KK2 FC and it flies just fine.
Jirv311 is offline Find More Posts by Jirv311
Old Apr 05, 2013, 05:11 PM
CSU Chico, Flight Club
Test Pilot Mafia's Avatar
United States, CA, Chico
Joined Sep 2012
High quality analog or digital servos, will be better than a low quality analog or digital servos.
be careful when making comparisons, and drawing conclusions.
my tri worked well with a single HS-225MG, Metal gear, analog, pretty good resolution, 31g. My MKS DS1009 servos
are way better -- metal gear, digital for 600-700 size helis, but there expensive and heavy, 62g.
Test Pilot Mafia is offline Find More Posts by Test Pilot Mafia
Discussion Should I use a Digital Servo with Metal Gears Robert N Multirotor Talk 3 Apr 04, 2013 12:19 AM
Discussion Centering Servos using a digital pitch gauge. SoftSpeaker Beginner Training Area (Heli-Electric) 1 Feb 12, 2013 10:28 PM
Discussion Should I use digital servos all around on T-REX SA? Timmskyline350gt Mini Helis 11 Jun 25, 2007 05:35 PM
90 size heli w/4 digital servos, what voltage should i use wac Fuel Heli Talk 7 Oct 31, 2005 03:12 PM
digital receiver used with digital servos? Cliff Walker Hitec/Multiplex USA 2 Jun 05, 2004 11:17 PM
