Old May 22, 2013, 02:17 AM
Joined Nov 2008
Originally Posted by ALEX HEWSON View Post
I will try for the Kevlar hinge method. The above tailplane has 2oz 45 biased kevlar in it already. I have some special HSS Scrapers for creating the Kevlar hinges
I would really like to try kevlar or peel ply hinges on the wings of the 40% scale ASG29 I am building and could do with some help and tips. I tried to use peel ply for the elevator and it nearly worked but I found it difficult to get the clearance on the top surface and then sort of glued everything back together when I tried to face the lower surfaces. My Father in Law lives in Christchurch and is coming over to the UK in mid June - is there a gizmo I could buy off you and he could bring to make it easier?
I'm not sure I would fully trust silicone for my hinges at this scale because I seem to be useless at doing those too!
Regards
Simon
swarrans is offline Find More Posts by swarrans
Old May 22, 2013, 06:11 AM
PB of 733kph
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
I will try get a video of when I cut the hinges. It will make it easier for you to follow
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old May 22, 2013, 06:18 AM
Neal
Christchurch, NZ
Joined Nov 2004
tonight I cut the tip joiner tubes into the end of the first wing panel. Had some fun with the foam cutter when it decided to do something odd. The left X axis missed steps going up at the wrong moment and put a skewed cut into the foam. Had a play with it and it would go down 10mm but then only 6. Did it a few times and not sure what it was. Adjusted the time values between steps, and checked all the drive thread connections, but nothing found. Working well agian now.
HotAir2 is offline Find More Posts by HotAir2
Old May 22, 2013, 04:50 PM
Blenheim, NZ
Joined Dec 2007
Have you made something up out of lathe tool bits? Any chance of a picture.
Allan
AllanK1 is offline Find More Posts by AllanK1
Old May 23, 2013, 12:38 AM
PB of 733kph
Joined Jul 2005
Yep, some High Speed Steel bits ground like thin parting-off tips. I scrap the outer surface along a straight edge till I get to the kevlar, but depending how I do the other side depends on if I cut a bevel, or cut behind the hinge and run a wiper..
Old May 23, 2013, 12:40 AM
PB of 733kph
Joined Jul 2005
Centre panels are ready for bagging. Wiring is in place and joiner ribs/tubing is in place at each end. Filled ready for a sand prior to perforating then bagging
Old May 23, 2013, 09:08 PM
PB of 733kph
Joined Jul 2005
Pics
Old Jun 01, 2013, 04:37 AM
PB of 733kph
Joined Jul 2005
FINALLY got the first centre panel in the bag today.
Fuse plug is polished and ready to go also
Old Jun 02, 2013, 11:16 PM
PB of 733kph
Joined Jul 2005
Pulled the first panel out of the bag today. Looks really good! A little dry on the side I layed up, but the side Neal and Graham did is perfect! Really surprised how stiff and strong it is!
Old Jun 02, 2013, 11:27 PM
macshack's Avatar
New Zealand, Marlborough, Blenheim
Joined Aug 2012
Alex, excellent videos. please inform me of when the 2013 fly in is happening. Ken McMillan
macshack is offline Find More Posts by macshack
Old Jun 03, 2013, 03:12 AM
PB of 733kph
Joined Jul 2005
The Lake Forsyth Fly-In? It is August 31st- September 1st.
Next Aerotow event is 27th 28th July at your home turf
Old Jul 19, 2013, 04:14 AM
New Zealand, Marlborough, Hawkesbury
Joined May 2010
Throwing blades
Alex
Don't forget to bring some dlg throwing blades when you come up to Blenheim. I will take a couple - would prefer sanded/finished ones. Thanks.
fishbed is offline Find More Posts by fishbed
Old Jul 20, 2013, 05:33 AM
PB of 733kph
Joined Jul 2005
Will bring some :-)
Old Feb 02, 2014, 01:45 AM
Joined May 2010
Alex
Any more progress on your ASW28-18 project? I have booked the new, larger field for our next aerotow here in Blenheim in July and it would be great to have a few more BIG scalies at the next one, as we now have ample runway and airspace to handle them.
Old Feb 03, 2014, 03:22 PM
PB of 733kph
Joined Jul 2005
No updates unfortunately. Some other projects have halted any progress
Article Part I: ICARE R/C Imports Let Model ASW 28-18 3m Slope/Thermal Flying Commplexxo Scale Sailplanes 21 Apr 10, 2014 04:49 PM
Discussion Fly Fly ASW 28 2.6M Aros Electric Sailplanes 7 Jul 19, 2013 08:54 PM
Wanted ASW 28-18 (3meter fuselage) Joe Casey Aircraft - Sailplanes (FS/W) 1 Jan 02, 2013 06:25 PM
Article Part II: ICARE R/C Imports Let Model ASW 28-18 3m Electrifying Scale Model Commplexxo Electric Sailplanes 25 Dec 04, 2007 11:46 PM
asw 28-18 shades Scale Sailplanes 15 Jun 03, 2005 04:45 AM
