Old Sep 07, 2014, 02:16 PM
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Yay, real steam :-)
Eventually, if the cost of butane gets to you, you can convert to propane. I converted all my Accucraft , G-gauge locos to propane. Pretty simple. Let me know when you get to that stage and I'll post details. The whole conversion procedure used to be on mylargescale.com, but they suffered a few server crashes over the years, and I think they lost everything from the past, alas.
Brooks is offline Find More Posts by Brooks
Old Sep 07, 2014, 07:27 PM
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
The Ronson cans are the most expensive way to buy butane. I found that you can buy 8oz cans in the Asian markets for about $1.00 a can, befor that I was paying $10.00 for four at Wally World or Home Hardware.
Regards,
Gerald.
steamboatmodel is offline Find More Posts by steamboatmodel
Old Sep 24, 2014, 11:27 PM
hookpilot's Avatar
Big Milestone for Preston
Preston now sits in Dave's shop for the steam engines to be installed. While the engines are being installed, we are moving to a beautiful new home on a lake. We have 100 feet of waterfront and a very nice dock. The move should take place October 15th. Preston's christening is now close at hand.
Snagboat Mike
hookpilot is offline Find More Posts by hookpilot
Old Sep 27, 2014, 12:48 AM
hookpilot's Avatar
Steam Engines Being Installed
https://www.youtube.com/watch?featur...&v=eLUrVIL6PYo
As noted above, the engines are being installed. The above video shows the completed engines running in their milling fixture. Once in the hull, a linear servo will be attached to the reversing gear and an oil lubricator system added. Dave will have the boat for a month and when he's finished, I'll take it to its new home on Island Lake near Shelton, WA. We are very excited to be moving in to the lake house in mid-October. There will be a christening and launch party sometime near the end of October. If any can make it, give me a shout on the forum and I'll send you particulars. Everyone is welcome. After almost 4 years and 3500 hours of build time and an additional 2 1/2 years building the steam engines, W.T. Preston will be set in the lake to get under way for the first time in less than a month. It should be a beautiful Fall setting to video the event. Thanks all for your interest in the build.
Snagboat Mike
Old Oct 15, 2014, 04:48 AM
hookpilot's Avatar
Preston Engine Install Update
Installing Preston's steam engines is a lot more complicated than slapping an electric motor or two in a model. Dave is aligning the engines so they are parallel and square with each other and the centerline of the hull, and properly aligned with the paddle wheel shaft and cranks. It is a very exacting process. If not done right, the engines will bind and not run smoothly. The photos below show this process. We had to find a datum from which to measure everything. Dave ran a snap line down the centerline of the hull. Now we have a good fixed reference point from which to align the engines and paddlewheel.
Left to do is get the engines accurately bolted in, machine the paddlewheel split bushings, rebuild the oil/water separator, machine the steam inlet and exhaust piping/flanges, make the elbow connecting the safety relief valve to the smokestack exhaust flange, install the cylinder drain valves, control servo and piping, and mount the steam oil lubricators.
Snagboat Mike
Old Oct 16, 2014, 11:54 PM
Brooks's Avatar
Joined Aug 2003
The inside of your boat is more interesting to me than the outside :-). The scale engines are very very cool.
Of course, your boat is very neat all around. What a magnificent result from all your efforts!
Old Oct 17, 2014, 12:55 AM
hookpilot's Avatar
Preston's Innards
I have a feeling Preston will make more than a few runs around the lake with her top off, just to show off the steam plant. I'm thinking a GoPro camera mounted looking aft showing the inner workings would make for interesting videos. By the way, I appreciate all the nice comments on our build. Dave is doing a fantastic job on the engines. I will be affixing a special engraved engine builder's plaque in the engine room to acknowledge his outstanding work.
It will be great fun to take the model up to Anacortes WA where the full size W.T. Preston is on display for photos. A second trip will be done to the US Army Corps of Engineers new Seattle office, Preston's ancestral home since commissioning in 1929. They are very keen to have me will the model to them.
Snagboat Mike
Old Oct 17, 2014, 01:11 PM
Brooks's Avatar
Joined Aug 2003
If they are Really Keen, you might think twice about going to sea with them: Nudge, Opps, Where did Mike go? *grin*
Oily steam from the inevitable whisps of leakage will not help your camera. I'd put it in a ziplock bag, with only the lens poking through a round hole in the bag. But I'd love to see the works while she's steaming on the water :-)
Old Oct 22, 2014, 11:31 AM
United States, MA, Mid-Cambridge
Joined Apr 2008
Originally Posted by Brooks View Post
Yay, real steam :-)
Mike at MacSteam says the camp stove mix of 60 Butane / 40 Propane is fine for his boilers. Just don't go over 40% Propane. I buy the big camp stove cans at Dick's. You will also need a fill valve converter from Forest Classics, which paid for itself on the first run. Way cheaper than the lighter refills!
Glen the Rotor is offline Find More Posts by Glen the Rotor
Old Nov 04, 2014, 12:10 AM
hookpilot's Avatar
Preston's New Home: Shelton
Day three on Island Lake and a few rooms are set up, but not the shop. This is going to be a model ship builder's dream... The lake is usually mill pond smooth. My new dock will work out well for launching and recovering my models. The new shop area is good size, but I'm starting from scratch- no bench,no storage, just walls. The steam engines are nearing their install in the hull, so maybe before the snow flies, Preston will take her maiden run. In the mean time, I'll get the Vosper Motor Torpedo Boat out and run it around the lake.
Mike in Shelton
Old Nov 24, 2014, 10:36 PM
hookpilot's Avatar
While I get my shop put together, Dave is hard at work moving along with the engine install.
Below photos show the most recent work. The reversing gear is in, including the linear servo. Sitting just forward and on the port side is the engine lubricator. It has two pistons delivering metered steam oil just before steam enters the engines. It will get busier in here with the addition of the cylinder drain valves, plumbing and servo. All the steam supply and exhaust tubing is yet to be installed, but we are getting close.
Being old school, I received a very nice drafting table and have that ready to place in my office. Anybody happen to have an old drafting machine they'd like to get rid of??? It's still fun and satisfying to sit down to a clean sheet of paper and draw out your creations.
Snagboat Mike on Island Lake
Old Nov 25, 2014, 11:27 AM
Toronto, Canada
Joined Nov 2004
Hi Mike,
Check out the secand hand shops, I picked one up for $15.00, without the scales they sold them seperate after taking off and throughing out the metal holding brackets.Fortunatly one of my aquantices is a pack rat and he sold me some.
Regards,
Gerald
Old Nov 25, 2014, 02:04 PM
hookpilot's Avatar
Originally Posted by steamboatmodel View Post
Hi Mike,
Regards,
Gerald
Thanks for the information on second-hand shops. I've also seen quite a few for sale on eBay. I'd prefer to see them in hand rather than order blindly through the internet.
Cheers,
Build Log 1/32 Scale W.T. Preston Sternwheeler Build hookpilot Scale Boats 1452 Nov 24, 2014 10:58 PM
Discussion Scale Doors and Fittings Umi_Ryuzuki Scale Boats 211 Oct 11, 2014 05:08 PM
Video W.T. Preston Crane Work hookpilot Dock Talk 1 Jul 02, 2012 06:44 PM
Discussion W. T. Preston in Anacortes Washington State Can Fly Land?? Aerial Photography 0 Feb 25, 2008 01:00 AM
