Old Dec 02, 2012, 10:10 AM
Joined May 2004
Plug in balance or power lead first?
I have two 10S's that I use to charge a variety of batteries. Was wondering if I should plug in the balance or power leads first. Does it make any difference if I am charging one or two batteries? Thanks for any replies.
Sit-N-Fly is offline Find More Posts by Sit-N-Fly
Old Dec 02, 2012, 11:32 AM
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
In the case of the Cellpro 10s charger, I'd recommend connecting the main pack leads up before plugging in the balance connectors. Sometimes you'll get a small spark when the output capacitor charges up. Your larger main pack connectors will have a better time of dealing with this than the small balance connectors pins.
Follow same process for one or two pack connection.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Dec 02, 2012, 01:23 PM
Joined May 2004
Thanks; will do.
Old Dec 03, 2012, 10:06 AM
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
How about the PL 8??
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Dec 03, 2012, 03:44 PM
Tim Marks's Avatar
Joined Mar 2008
Hi:
PL8 is opposite order. Plug the balance leads in first, then the power leads. This is because PL8 has surge protection circuitry. It only works if you plug the balance leads in first, and it virtually eliminates any sparking when you do it this way.
Tim Marks
Old Dec 03, 2012, 04:31 PM
traxx de maxx's Avatar
uk
Joined Nov 2010
and when you remove does it matter, or is it balance leads last. I think i just got into the habbit on my last charger of doing balance leads first, then last to remove. pl8
traxx de maxx is offline Find More Posts by traxx de maxx
Old Dec 03, 2012, 11:54 PM
Tim Marks's Avatar
Joined Mar 2008
Hi:
Order of removal does not matter.
Tim Marks
Old Dec 04, 2012, 06:06 AM
uk
Joined Nov 2010
cool thanks.
Old Apr 02, 2013, 07:16 AM
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
Originally Posted by Tim Marks View Post
Hi:
Tim Marks
Is it the same as PL6 in this regard?
What if I am using PL6 + MPA, since paralel charging need to plug main lead first to avoid inrush current and sets off the polyfuses
Thanks.
rizky_p is offline Find More Posts by rizky_p
Old Apr 02, 2013, 11:55 AM
Seattle
Joined Sep 2007
Thanks.
The Powerlab6 is different. There no advantage to plugging the balance leads first. Go ahead and connect the main leads first.
Gregor99 is offline Find More Posts by Gregor99
Old Apr 02, 2013, 12:04 PM
rizky_p's Avatar
Joined Apr 2007
Discussion Pulling power through the balancer plugs, good or bad? GreenAce92_v2 Power Systems 6 May 05, 2013 03:10 AM
Help! Low Voltage warning in iCharger 306B when plugging in balance port, please help jasper7821 Batteries and Chargers 15 May 04, 2012 12:57 PM
Discussion Confused! has balance lead polarity changed in the recent past or wot? Rick. Batteries and Chargers 7 Apr 15, 2012 09:42 PM
Question Plug in balance lead or my deans in 1st? Alpha_Geist Batteries and Chargers 3 Apr 13, 2012 01:12 PM
Discussion balance lead plug for Thunder power li po's nigel mcloughlin Batteries and Chargers 13 Aug 31, 2008 11:20 PM
