Old Oct 11, 2012, 04:28 PM
United States, OH, Loveland
Joined Feb 2007
Washout in foam
How do I put washout in a foam wing? I have a Cularis and it loves to tip stall. Would washout help it from not tipstalling. If not what?
sinowace is offline Find More Posts by sinowace
Old Oct 11, 2012, 04:29 PM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
when is it tip stalling?
Thermalin is offline Find More Posts by Thermalin
Old Oct 11, 2012, 06:38 PM
Joined Feb 2007
It tip stalls when I'm in a turn trying to thermal.
Old Oct 12, 2012, 10:29 AM
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Looks like there are 2 threads with the same name
http://www.rcgroups.com/forums/showthread.php?t=1749795
rcav8r2 is offline Find More Posts by rcav8r2
Old Oct 12, 2012, 02:59 PM
Thermalin's Avatar
Joined Jan 2005
Some sailplanes turn tightly better than others. I've had some that would pivot on a wing tip...
Old Oct 12, 2012, 03:07 PM
iva
iva's Avatar
Vancouver Harbour Sp, Canada
Joined Jan 2001
Try increasing aileron differential. That would be the easiest and fastest solution.
iva is offline Find More Posts by iva
Discussion Making a foam cored wing using 2-part rigid polyurethane foam in the mould. AvB Composites Fabrication 272 Nov 11, 2014 12:58 AM
Discussion Washout in foam sinowace The Builders Workshop 2 Oct 12, 2012 12:38 PM
Discussion Foam for cores ? Also tip template placement for washout? CoolerByTheLake The Builders Workshop 19 Oct 06, 2012 07:30 PM
Discussion Washout in cnc mold tdkamila Composites Fabrication 16 Mar 31, 2012 09:31 AM
Wing washout in foam armourgod Foamies (Kits) 12 Jan 16, 2004 01:33 AM
