Old Aug 21, 2012, 04:39 PM
United States, AL, Foley
Joined Jul 2011
Question
Ultra copper sealant
How long does it need to cure before running eng.? I replaced the pitts muffler on a dle 30. Thanks
boatman1950 is offline Find More Posts by boatman1950
Old Aug 21, 2012, 10:43 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I would suggest overnight at the very least, 24 hours is better.
The instructions say to apply the bead, re-assemble, but do not tighten down all the way, stop when it starts oozing out between the parts, then wait at least two hours better is overnight.
Other guys who use it just go ahead and start using their engine after they re-assemble everything. The tube of stuff can go bad after some long period of time and then it stops curing on you.
ref http://www.google.com/url?sa=t&rct=j...8kd_EQ&cad=rja
earlwb is online now Find More Posts by earlwb
Old Aug 21, 2012, 10:58 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
+1 at least overnight. I used it on Saito mufflers and it is the only thing that keeps them tight. Great stuff if you let it cure.
Fokker DII is offline Find More Posts by Fokker DII
Old Aug 23, 2012, 05:31 PM
Joined Jul 2011
Copper sealant
Thanks for the info. Iwill wait overnight and try it.
Old Aug 26, 2012, 08:34 PM
Mikecam's Avatar
Canada, MB, Winnipeg
Joined Apr 2008
I've had better luck just tightening down the muffler and waiting over night. It seemed to me that the sealant was skinning over and blowing out to easy when doing the finger tight for one hour first method. Also take some 200 grit sand paper to both surfaces to scuff them before mating.
Mikecam is offline Find More Posts by Mikecam
Discussion Tungsten Copper for Ballast RCRod Multi Task F3X 4 Jul 06, 2012 08:07 PM
Discussion Spray foam sealant? numba Hand Launch 4 May 31, 2012 11:17 PM
Discussion What's the best foam sealant? faststick Foamies (Scratchbuilt) 3 Mar 03, 2012 08:25 PM
Discussion Turnigy Pure Copper Wire: Where's the copper? AerialMike Batteries and Chargers 3 Mar 01, 2012 10:15 PM
Discussion Deans Ultra (copper vs ?) ktmrider Micro Helis 1 Mar 04, 2006 03:46 AM
