Old Jan 23, 2012, 06:58 AM
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Originally Posted by Ken Lilja View Post
Wouldn't vortex generators be easier?
Ken
Yes, and as well as on airliner wings, you can occasionally see them on some racing cars.
Shedofdread is offline Find More Posts by Shedofdread
Old Feb 20, 2012, 12:02 PM
F1B is ok.
Monheim am Rhein Germany
Joined Jul 2008
I do not know where to post this picture. Please move.
The Horten brothers with glider.
Heinz
hastf1b is offline Find More Posts by hastf1b
Old Feb 20, 2012, 12:46 PM
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Would you have any photos of the race car version?
Knoll53 is offline Find More Posts by Knoll53
Latest blog entry: Sw-11
Old Feb 20, 2012, 05:30 PM
Derbyshire, UK
Joined Aug 2008
Not to hand, no. However, from memory the ones I've seen look like little shark's fins. I've seen them both on the suction side of rear wings and occasionally upstream of the rear wing on the engine cover. Clearly aero aids like this are only used on cars developed in wind-tunnels because get them wrong and they're worse than useless.
Hope that helps and if I come across any pics I'll get them to you.
Old Feb 23, 2012, 06:40 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Description:
Stupot46 is offline Find More Posts by Stupot46
Old Feb 24, 2012, 03:36 PM
Stupot46's Avatar
Joined Sep 2011
Been playing about with chuck gliders.First one about 15" span was a bit heavy,but with a tail it's made a good catapult plane for my grandson,he's well pleased.This one is about 24",tried it with a tail to get cg some where near,then cut some drag rudders.Seems to glide a good line,but haven't much space indoors and it's been to windy to try outside.Both these have a flat bottom foil,I'm going to buy some more 2mm depron tomorrow,see if I can produce a symmetrical wing with a bit of linear twist,maybe a bit bigger.
Old Feb 24, 2012, 04:11 PM
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Looking good. The one I built had 2 degree geometric washout and never flew without vertical stabilizers at the wing tips. I never explored any other ways for yaw stabilization and interested in your yaw rudder design. The wing ribs were EH 1.59.0 and worked a lot better than the clark y I tried before. CG was 12" back from the wing root.
With the EH 1.59.0, the plane performed much better but they broke from the attachment point to the fuselage when I was in a manuver. I was able to salvage the wings and installed them onto another fuselage(picture). This plane is fast and very maneuverable with this airfoil.
p901P901 is offline Find More Posts by p901P901
Old Feb 24, 2012, 05:47 PM
Stupot46's Avatar
Joined Sep 2011
Thanks p901,I was reading your previous post earlier.After I got it gliding with tail etc,just added a touch more lead shot in the nose,cut the t/e to make the rudders and was pleasantly surprised.Like I said,need to get a longer flight.I aren't going to cut ribs,just do a folded l/e,couple of depron spars and see how good a foil results.Been following your input on Franks thread,very interesting although the electronics are way over my head.
btw any progress on the mid prop?
Regards Stuart
Old Feb 24, 2012, 07:22 PM
p901P901's Avatar
Joined Jan 2009
Regards Stuart
My HOx went through many changes and crashes to make it fly right. I hope yours will be a nice flyer. It is a really good looking design.
Mid prop is going fine. Working on forward fuselage and wings, no pictures, just pre fitting parts.
I hope Frank continues working on his design. It looks like he is making good progress.
Old Apr 12, 2012, 07:12 AM
USA
Joined Apr 2007
just found this http://www.rcgroups.com/forums/showthread.php?t=1631238
space 1 is offline Find More Posts by space 1
Discussion Has anybody made a HE 162 Volksjager as a rc plane ace128 Electric Warbirds 10 May 05, 2006 12:10 PM
Question Hox to order on Neu's site sboub High Performance 9 Feb 07, 2006 01:34 PM
Peter Rake Volksjager elp914 Scale Kit/Scratch Built 16 May 15, 2004 10:12 AM
Hobby Lobby Heinkel He-163 Volksjager The Max-Q Electric Ducted Fan Jet Talk 3 Jun 08, 2003 05:20 PM
KAVAN EDF HE-162 (Volksjager / Salamander) deadduck Electric Ducted Fan Jet Talk 13 Mar 26, 2003 11:18 PM
