Old Nov 19, 2011, 09:51 AM
USA, LA, Mandeville
Joined Feb 2005
Waterproofing chemical
This stuff looks great! I wonder if it can be used on electronics.
http://wimp.com/superhydrophobiccoating/
And more info http://www.neverwet.com/
hew565 is offline Find More Posts by hew565
Old Nov 19, 2011, 10:41 AM
hiljoball's Avatar
Canada, BC, Lake Cowichan
Joined Jul 2011
Would depend upon its electrical conductivity. If it conducts electricity, it could cause shorts.
John
hiljoball is online now Find More Posts by hiljoball
Old Nov 19, 2011, 11:21 AM
thorsail's Avatar
Chicago , Illinois
Joined Jul 2008
hew565
There already is a product made for our applications in RC boats.......
check out this websiste : //corrosionxproducts.com
or for those in the midwest region: www.greatlakescorrosion.com
actually, this could be something a club could buy -because a little goes a
long way. I bought the "trigger spray" 16 oz. bottle - for 2 good reasons.
1) I am leery of aerosols lasting a long time,on something I use seldom,
and are semi-expensive-trigger spray will last forever
2) I like being able to open bottle,dispense,re-bottle and cap...see below
In my use, I pour an inch(or so) of the Corrosion X into a dixie cup -
and I take hold of my RX and DUNK it into the Corrosion X ! holding it by
the antenna wire - then with a stirring stick hang the RX over the cup
until it stops dripping -ie:is dry. then I can pour the leftover liquid back into
the bottle.I also take the connector ends of my servo's and dip them into
this product to protect them.
hope this helps
Allan
thorsail is offline Find More Posts by thorsail
Old Nov 19, 2011, 12:00 PM
So. Cal. Glider
Costa Mesa
Joined Mar 2007
Hew,
Sounds very interesting. Maybe even use it on the hull of a model yacht?
For electronic uses there is the question of conductivity.
Unfortunately the company says it will not be available in retail spray cans until sometime in 2012.
rcandgolf is offline Find More Posts by rcandgolf
Old Nov 20, 2011, 01:12 PM
Rick Lange
Cleveland, Ohio, USA
Joined Apr 2010
Depending on which side of the border you want to buy, CorrosionX and Corrosion Block are oil based for adhering to metals. NeverWet is nanofilm based.
From the NeverWet white paper, they have used it successfully to prevent corrosion in an industrial switch, so conductivity shouldn't be a problem.
Blue Heron is offline Find More Posts by Blue Heron
Old Nov 20, 2011, 11:06 PM
Joined Jan 2006
There is a nano coating out there that does work on electronics, but it has to be applied under vacuum. Not really a do it yourself proposition, but it does work and is being used in industry. Company is P2i.
slotracer577 is offline Find More Posts by slotracer577
Discussion Waterproofing south.tx.dead.I Waterplanes 15 Oct 30, 2011 02:12 PM
Discussion Ideas for waterproofing balsa needed zbrubaker Waterplanes 10 Oct 01, 2011 08:28 PM
Mini-HowTo Waterproofing and rx water test. Diesel6401 Racing Boats - Electric 7 May 07, 2011 09:40 AM
