Old Oct 05, 2014, 05:59 PM
I want just one more plane!
timwj1's Avatar
United States, ID, Idaho Falls
Joined Feb 2013
Thank you for asking about expo, I put expo on all planes and on my 3D ailerons I'm using up to 80%. I switched radio systems this spring, I now use the Aurora 9 and it seemed like my flying skills went to s--t! Today I asked my flying buddy to move this aileron sticks as fast as possible to compare to mine which were lightning fast. Turns out I'm a dummy, didn't even know Aurora 9's used negative instead of positive expo, no wonder my flights feel like a bucking bronc ride, at 80% expo the wrong way?? Condor 84's post of his rates last night got me thinking, I should have noticed the reverse expo, high rates was scary scary scary. Now I get to learn how to fly all my planes again, the right way!
timwj1 is offline Find More Posts by timwj1
Old Oct 05, 2014, 07:03 PM
Wamp's Avatar
Joined Mar 2012
Just had a conservation about that at the field this afternoon.
Who needs jitters!?
Wamp is offline Find More Posts by Wamp
Old Oct 05, 2014, 08:35 PM
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
...didn't even know Aurora 9's used negative instead of positive expo, no wonder my flights feel like a bucking bronc ride, at 80% expo the wrong way??
Wow, 80% the WRONG way?!@!
You sir are quite a pilot not to crash everything, I probably would have!
Sammy70 is offline Find More Posts by Sammy70
Old Oct 05, 2014, 09:02 PM
timwj1's Avatar
Joined Feb 2013
ha ha, it sure explains why I tore out a few landing gear and then bent some motor shafts late springtime. Luckily everything was easy repairs, live and learn!
Old Oct 05, 2014, 11:39 PM
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Originally Posted by wollins View Post
Having said that, are you guys using expo on this bird, and if so how much?
Colin
Thanks guys!
Colin
wollins is offline Find More Posts by wollins
Old Oct 06, 2014, 05:47 AM
Condor84's Avatar
United States, FL, Hastings
Joined May 2013
Holy hell..I tried flying with +50 expo once on my Aurora with a tried and true airplane just to see what it was like...I promptly hit the switch and never did anything like that again. You must be quite the pilot indeed. But, I don't blame you. After using Futaba forever, I had a hard time remembering to put in negative expos instead of positive ones, and every now and then when programming one of my old Futabas, I catch myself putting in negative. Did you notice, however, that it seems to require more expo in the Aurora for an equivalent to some other radios?
Now, I can just imagine flying the Cosmic Wind on 98% positive expo on high rates. If one could fly and land, they'd surely have bragging rights for quite awhile.
Condor84 is offline Find More Posts by Condor84
Old Oct 06, 2014, 10:11 AM
timwj1's Avatar
Joined Feb 2013
Yes, I agree, it seems the Aurora 9 increments are much smaller than the Spektrum I used, same with trim settings, it takes a while to get used to it but I really like the Aurora 9. I liked it so well I bought 2, and have the planes I don't care for on the 2nd one, its nice to have a backup.
Old Oct 06, 2014, 03:43 PM
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
Ripped one of my main landing gear off today while landing I got snagged in a prop strike tear in the textile runway
jk6672 is online now Find More Posts by jk6672
Old Oct 06, 2014, 05:29 PM
Wamp's Avatar
Joined Mar 2012
Bummer
Old Oct 13, 2014, 07:29 AM
Joined Oct 2012
Hi, I had the CW with rimfire 15, mostly running on 3S, 2200mAh and sometimes with 4S but in high speed it has vibration and can not keep with the speed . Unfortunately it had an unpleasant meeting with the ground and the fuselage was damaged. now I am in the question of what to do?
Option 1: built it with the same setup of Rimfire 15, 45A ESC and APC 8X8
Option 2: Built it with same setup but make some improvement to be able to run 4S with no vibration, have no idea how to do it?
Option 3: Built it with Rimfire 10 and use only 3S and maybe gain some W so I will not loose much speed
Option 4: Try to look for something similar but little bigger like the great plane proud bird, or the Great Planes F-1 Rocket Evo or any other idea.
Thanks for your help.
Udi
I will be happy to get any inputs
ugavish is offline Find More Posts by ugavish
Old Oct 13, 2014, 08:51 AM
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
You will undoubtedly get votes on all your choices from different people..
Cocg is online now Find More Posts by Cocg
Old Oct 13, 2014, 01:29 PM
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Alternate for the CW...
Udi
...could be the HK Invictus for your Option 4. Very nice lookin' bird that's a bit larger than the CW, if you're considering moving up to the EF-1 class ships...... The Invictus stock status (today) shows that it's available in the States as well...
RCAV8T0R is online now Find More Posts by RCAV8T0R
Sold GP Cosmic Wind Minnow ARF NIB 60 size, and others midwest_plans Aircraft - Fuel - Airplanes (FS/W) 0 Nov 04, 2010 08:14 AM
Found GP Cosmic Wind (Minnow or Lil Toni) or GP Revolver-RTF GoingVertical Aircraft - Fuel - Airplanes (FS/W) 0 Nov 04, 2007 02:18 AM
Discussion Recommend 4 stroke for GP Cosmic Wind Minnow RobNHood Engines 2 Aug 18, 2007 01:51 PM
