Old Jul 23, 2003, 04:00 AM
Normen Strobel
Guest
n/a Posts
welder's rods
I'm currently building the ailerons for my Stuka and the plans say to use
3/32 Welder's rods as the hinge pins. What are welder's rods, are they
flexible, stronger? How do they compare with Music Wire?
Normen Strobel
nstrobel@email.uophx.edu
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
James Holbrook
Guest
n/a Posts
Re: welder's rods
They are not tempered steel so they are easier to bend and thread if you
need to. Have used them fro years so they are plenty strong.
"Normen Strobel" <nstrobel@nospam.zoominternet.net> wrote in message
news:3f1d6c14_6@corp.newsgroups.com...
> Normen Strobel
Old Jul 23, 2003, 04:01 AM
Mitch
Guest
n/a Posts
Re: welder's rods
They're talking about gas welding rod. Normally is copper coated mild
steel, normally in 36" lengths. Much more ductile than music wire. Can be
cut and threaded.
Rein
> Normen Strobel
Normen Strobel
Guest
n/a Posts
Re: welder's rods
Thanks. Where can I get them, will Home Depot or Lowes carry them?
Normen Strobel
"James Holbrook" <jameslnm@comcast.net> wrote in message
news:rB2cnfM6PMUu5ICiXTWJiA@comcast.com...
use
> > Normen Strobel
Pjtg0707
Guest
n/a Posts
Re: welder's rods
On Tue, 22 Jul 2003 14:34:39 -0400, "Normen Strobel"
Home Depot carries mostly spools of wires for either MIG or fluxcore
welding. You want either gas welding or TIG welding rods. Your best
bet is to get them from a welding supply house by the box. Your best
bet is to get regular wires in smalll quantities from hobby shop if
don't plan on using the whole box for weldng.
emcook@yahoo.com
Guest
n/a Posts
Re: welder's rods
In rural area's most feed & seed, farm/gardern, tractor implement,
auto parts stores, welding supply, and local hardware stores keep them
in stock.
Northern Hydraulic's or Tractor Supply Co. would be 2 chain stores
that should stock them.
Lowes, Home Depot many have some of the small packs of 12" rods.
Fred McClellan
Guest
n/a Posts
Re: welder's rods
On Tue, 22 Jul 2003 12:50:52 -0400, "Normen Strobel"
Welder's rods are . . . . rods welders use.
Alloy steel in various flavors, not heat treated. You can get bronze
and aluminum alloys as well, but that wouldn't do for hinge pins.
Buy 'em by the pound in any half-decent welding supply shop.
Don't bother with BORG rods, they'll likely be flux coated and you
want the bare rods.
I use 1/8" rods for making 4-40 threaded stuff.
Cheers,
Fred McClellan
the dash plumber at mindspring dot com
