Old Jun 29, 2009, 08:03 PM
AMcC's Avatar
Australia, NSW, Sydney
Joined Jul 2008
WW2 dual leg landing gear
I have a 66" Handley page Hampton 50% completed and I have hit a bit of a wall with the landing gear. Does anyone have any ideas/links to how to make the dual leg landing gear used on WW2 bombers. It does not have to be exact scale etc. I already have the air retract mechanisms fitted into the nacelles. I was going to use single sprung oleo from Hobby city (I know not scale) but they are too long and don't clear the air cylinder anyway. Any help much appreciated.
cheers
AMcC is offline Find More Posts by AMcC
Old Jun 29, 2009, 08:55 PM
TKG
Riverton Wy
Joined Apr 2003
A 5/16 almunium rod. Drill 3 holes in it. Stick the retract leg in the center hole and the strut legs in the outer holes. Use 2 bolt on axles with a brass tubing coupler for the wheel to turn on.
TKG is offline Find More Posts by TKG
Old Jun 30, 2009, 05:01 AM
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
On my long departed Lancaster I just bent the standard Rhom Air 3/16 wire leg 90 deg sideways after the coil then 90 deg down then 90 deg again for the axle. The other leg was just a dummy supported by the cross bracing between the legs. - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Jul 03, 2009, 08:38 AM
All under control, Grommit!
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Hi
Tom Hunt's excellent realisation of twin leg landing gear that might be suitable, with modification, for a HP Hampton.
http://www.rcgroups.com/forums/showthread.php?t=77588
hth
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Jul 03, 2009, 09:35 AM
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Thanks for the link Brian. I am struggling to come up with with a workable set of semi-scale gear for my GAD Lanc, and so far am 0 for 3. Some fresh ideas are most welcome.
Regards,
Jeff
jhspring is online now Find More Posts by jhspring
Old Jul 03, 2009, 12:19 PM
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Does it have to be air driven?
Alfa models have a twin leg retract set-up for their Beaufighter which I bashed into a He111.
May be small for a 60" span but the technique is clever.
Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Jul 03, 2009, 01:46 PM
Oh no, not again!
jhspring's Avatar
Joined Dec 2005
Phil, the Alpha's are the perfect design for a twin leg set-up, especially an in-line where lateral space is tight. Unfortunately, even paired, they are only good for an AUW of maybe 3 lbs. The Lanc is nearly twice that, and Walts has quit flying his b/c the gear fails every other landing. I also made a set-up with modified DSR units, but Fahim ripped his out of the B26 for the same reason -- at 4 lbs AUW the gears stripped every outing.
I am currently trying to modify a pair of GP 0.10 retracts, but first tests aren't too promising. It's pretty frustrating. I am looking at maybe trying a Robart 600 set modified like Tom's. Apparently the 90 degree bend in the primary leg provides enough give so the struts don't bend. I may have one more go with the GP units before I move to the Robarts.
FWIW,
Jeff
Old Jul 03, 2009, 04:53 PM
leccyflyer's Avatar
Joined Sep 2000
Jeff
The best small retracts that I've seen are the ones marketed by Flightline, whilst the medium sized ones are perfect as the basis of a set for the HVP Beaufighter, with modification to twin legs.
http://www.horizonhobby.co.uk/aeroon...9retracts.html
They are very reasonably priced too - the Beau set that my pal bought was about thirty pounds.
Old Jul 03, 2009, 07:22 PM
Oh no, not again!
jhspring's Avatar
Joined Dec 2005
Thanks Brian, I'll check them out. Much appreciated. Jeff
Old Jul 04, 2009, 04:12 AM
leccyflyer's Avatar
Joined Sep 2000
No probs Jeff - I'll take my camera to club night on Tuesday, on the off chance that my pal has his modified retracts ready for then.
Fiberglass Landing Gear Construction ???'s Steve McBride Electric Plane Talk 5 Aug 19, 2009 03:10 AM
Help with BN2 landing gear please. (dual wheels) kansascloud Parkflyers 0 Dec 04, 2003 05:03 PM
Taking off w/ landing gear and no rudder--HARD! totalboss Electric Plane Talk 5 Sep 10, 2001 01:09 AM
Wire size for landing gear Kevin Klejwa Beginner Training Area (Aircraft-Electric) 4 Sep 08, 2001 01:12 AM
GWS Pico Cub J3 FD landing gear modification pictures. flytowner Parkflyers 0 Jun 21, 2001 01:37 AM
