Old Feb 07, 2006, 10:11 AM
Jack
Guest
n/a Posts
Shuttle ZXX Blade Grip Question
I'm rebuilding the blade grips on a ZXX with stock pieces. The instruction
drawings, working from the inner portion out, show a ball bearing, a thrust
collar, a thrust race, the thrust bearing, another thrust race, and finally,
another ball bearing. My question centers around the thrust collar. If I
place the flat side of the thrust collar against the first thrust race and
bolt it all together there is zero play axially within the blade grip, but
axially it is very tight. However, if I flip the thrust collar over, and to
what seems logical, have the recessed side of the thrust collar seated
against the first thrust race and bolt it together again, there is seemingly
10 to 20 thousandths axial play in the grip. The drawing is not overly clear
on this, but seems to show, counterintuitively, the flat portion of the
thrust collar against the first thrust race.
Would like to know which way it's supposed to go.
TIA,
Jack
Old Feb 09, 2006, 12:11 AM
Bjarte IndrebÝ
Guest
n/a Posts
Re: Shuttle ZXX Blade Grip Question
If you do the question in www.runryder.com , I am sure you will get an
answear.
Bjarte
"Jack" <jfessler@triad.rr.com> skrev i melding
news:kY1Gf.10715$915.760@southeast.rr.com...
> thrust collar, a thrust race, the thrust bearing, another thrust race, and
> finally, another ball bearing. My question centers around the thrust
> collar. If I place the flat side of the thrust collar against the first
> thrust race and bolt it all together there is zero play axially within the
> blade grip, but axially it is very tight. However, if I flip the thrust
> collar over, and to what seems logical, have the recessed side of the
> thrust collar seated against the first thrust race and bolt it together
> again, there is seemingly 10 to 20 thousandths axial play in the grip. The
> drawing is not overly clear on this, but seems to show,
> counterintuitively, the flat portion of the thrust collar against the
> first thrust race.
> TIA,
> Jack
Old Feb 09, 2006, 02:11 AM
Aidar Lees-Leesmaa
Guest
n/a Posts
Right way is (from in to out): ball bearing, thrust collar with recessed
side inside (to ball bearing) and flat side outside (to thrust race), thrust
race with bigger inside hole (yes, thrust races have different hole sizes,
not much but different), thrust bearing, thrust race with smaller hole, ball
bearing.
Sorry my english, i hope you understand what i am trying to say here.
"Jack" <jfessler@triad.rr.com> wrote in message
thrust
finally,
to
seemingly
clear
> TIA,
> Jack
Old Feb 09, 2006, 06:11 PM
Jack
Guest
n/a Posts
Aidar,
Your English is great. Thank you so very much for your assistance!
Best To You,
Jack
"Aidar Lees-Leesmaa" <aidar@laevakompanii.ee> wrote in message
news:43eaf177$1_1@news.estpak.ee...
> thrust
> ball
> bearing.
>> instruction
> thrust
> finally,
>> and
>> but
> to
> seemingly
> clear
>> TIA,
>> Jack
Question CP2 CNC blade grip question... elan Micro Helis 0 Jul 13, 2006 10:19 AM
Found Hirobo Shuttle ZXX Blade Grips with bearings cptsnoopy Aircraft - Electric - Helis (FS/W) 0 Jan 15, 2006 11:35 AM
Corona Blade Grip Question JasonD Electric Heli Talk 3 Sep 03, 2002 10:44 AM
VE metal blade grip question Vance Electric Heli Talk 0 Jul 20, 2002 09:23 PM
