Old Oct 24, 2004, 02:43 PM
Austin Bergstrom, Texas, United States
Phoenix 25 to motor connection -- is it right?
Hi:
I got the Himax 2025-4200 motor and Phoenix 25 ESC. The motor has the male gold bullet connectors:
The following pic shows the three wires of the Phoenix ESC.
My questions are:
1. Am I supposed to simply "solder" the 3 wires to the inside of the provided female connectors, as suggested in the pic?
2. As shown in the pic, what is the purpose for the hole in the female connectors?
3. Do you use heat shrink to wrap around the female connectors for insulation?
Thanks a bunch!
yikan is offline Find More Posts by yikan
Old Oct 24, 2004, 03:55 PM
Really Cool User
Silverstreak328's Avatar
Tampa St Pete, Florida, United States
Joined Dec 2003
1. Yes, make sure you tin the wires first!
2. The hole is so you can solder the wire in at 90 degrees if you wanted and also serves as a spot to heat the solder up if you wanted to desolder the wire from it.
3. Yes.
Silverstreak328 is offline Find More Posts by Silverstreak328
Old Oct 24, 2004, 04:07 PM
Cool. Thanks!
Article Multiplex Brushless Motor BL480-8D/CC Phoenix 25 ESC Review Michael Heer Power Systems 28 Nov 26, 2005 12:38 AM
Phoenix 25 - Himax motor just oscillates DaleM Power Systems 29 Jun 19, 2004 09:46 AM
Connecting CC Phoenix 25 to Motor Tom Frank Power Systems 4 Jun 11, 2004 01:30 AM
Phoenix 25 - won't start motor every 8th time JoeCrasher Castle Creations 328 Mar 22, 2004 01:47 PM
motor run-on with phoenix 25 bracicot Power Systems 10 Nov 18, 2003 06:57 PM
