Old Jan 13, 2014, 03:23 PM
USA, OR, Portland
Joined Oct 2009
Lilliput 664/w FPV Monitor Wireless Issues
Hi guys,
Not sure if anyone has one of these monitors on hand but a little bit of help with my investigative testing.
I recently purchased one of these monitors as it has an IPS display, relatively bright and good outdoor visibility, built in receiver and battery tray and no bluescreen.
I also have the AVL58 kit from DJI.
I specifically ordered the Lilliput unit that has the same frequency and channels as the AVL58 but alas it's not working to my satisfaction.
Channel to channel, the two devices don't seem to talk on the same channels but I've done some testing and have come up with the following frequency matching.
As you can see, the lilliput will receive on the corresponding AVL58 TX channels but with some noise. On the lilliput, I have an omni antenna since it has an SMA connector and I couldn't use the AVL58 CL Antenna with the receiver till I receive an rp-sma to sma converter.
Using the AVL58 receiver, channels match up perfectly. I'm trying to determine if it's at all possible to receive video signal on multiple channels that are completely different subfrequency of the 5.8ghz spectrum. Working with the seller to see if it's possible the factory might have sent me a wrong version.
Here's what the Lilliput has in terms of models.
CH1 CH2 CH3 CH4 CH5 CH6 CH7 CH8
A 5705 5685 5665 5645 5885 5905 5925 5945
B 5865 5845 5825 5805 5785 5765 5745 5725
C 5733 5752 5771 5790 5809 5828 5847 5866
D 5740 5760 5780 5800 5820 5840 5860 (FAT SHARK RECEIVER)
Here's what the AVL58 lists as frequencies.
CH1-CH8
 CH1:5705MHZ
 CH2:5685MHZ
 CH3:5665MHZ
 CH4:5645MHZ
 CH5:5885MHZ
 CH6:5905MHZ
 CH7:5925MHZ
 CH8:5945MHZ
Thanks guys.
ajafar is offline Find More Posts by ajafar
Old Feb 20, 2014, 09:52 PM
asonkin's Avatar
United Kingdom, Uxbridge
Joined Jan 2014
Hi, have you found the solution for the problem? Can it be Lilliput monitor and not transmitter?
I have AVL58 set to channel 1 (5705) and 702 diversity monitor set to band A channel 1 (same 5705) and no problem with the video. I also had 701 (just sent it for repair) with the same setup and video was good. I haven't tried long range yet (200m max) but within this range video is flawless.
asonkin is offline Find More Posts by asonkin
Old Yesterday, 05:13 AM
Greece
Joined Sep 2009
back from the dead since i got this monitor and the reception so far is not very good.
Have issue for setting 664/W 8 default channel with DJI AVL58 tansmitter,please see below information :
http://lilliputweb.net/field-monitor...ors/664-w.html
OrfeasGR is online now Find More Posts by OrfeasGR
Cool Best FPV monitor!? Lilliput 664/W 7" Made for FPV with 5.8ghz 1280x800 Intelligent HD KillerCut FPV Equipment 5 Feb 21, 2014 01:55 PM
For Sale Lilliput 7" Monitor FPV TV HDMI + Hood & Accessories abonto FPV Equipment (FS/W) 4 Jan 26, 2014 09:27 AM
For Sale Reduced to Clear… Gaui 500x Quad, Spektrum DX7, FPV t/x r/x, Lilliput Monitor Ray2.2 Aircraft - Electric - Multirotor (FS/W) 3 Apr 09, 2013 09:52 PM
For Sale 900mhz rx/tx and Lilliput Monitor Ray2.2 FPV Equipment (FS/W) 0 Mar 14, 2013 04:47 PM
