Old Mar 17, 2013, 10:28 PM
Joined Feb 2013
R2008SB Antenna Position on F550
Hello!
I'm just now wrapping up my build of my first F550 using a Futaba T8J with R2008SB receiver. I have the receiver mounted to the right of the Naza somewhat near the edge where I had good surface area for the velcro (and decent accessibility).
In this position, the two gray antenna wires easily go down through one of the openings in the bottom of the F550.
What is the ideal antenna position? Just let them stick through this nearby opening and let them be? Tape them down somehow? Should they be hanging free or fastened and, if fastened, what orientation should they have? The manual indicates 90 degrees, but I'd like to know how others and handling it. 90 degrees to me would be one taped to the bottom of the baseplate and the other probably hanging free... but I doubt this is right.
Pictures, of course, are always appreciated.
Thanks!
- Aaron
halfpress is offline Find More Posts by halfpress
Old Sep 16, 2013, 04:25 PM
Joined Aug 2013
Hi,
I'm having the same problem. I wonder if you found a solution! i was looking at putting on the arms but it seems a little unsecured.
I have the R6303SB so its a tiny receiver but the antennae arms are actually quite long.
thekash is online now Find More Posts by thekash
Old Sep 18, 2013, 08:16 AM
United States, KY, Morehead
Joined Jan 2005
Aaron, As long as you have the (2) uncovered ends 90deg to each other and not touching anything that is conductive it will work fine. The covered part of the cable is "ok" to touch metal and CF but I would try to avoid it if possible. Your method should be fine just make sure the uncovered ends are out in the air and not resting on the baseplate.
skew is offline Find More Posts by skew
Discussion Opinions on F550+Heavy Lift Kit hativa1 Multirotor Talk 7 Nov 11, 2013 06:30 PM
Discussion Vee antenna position help ls1elite FPV Talk 7 Feb 07, 2013 11:39 PM
Question Hook position on Sloper Siggy101 Sailplane Talk 11 Jan 25, 2013 10:37 AM
Question Mounting NAZA GPS like this on F550? Rehost Multirotor Talk 4 Jan 12, 2013 12:10 PM
Help! 2.4 antenna positionning on a all carbon Miraj sruelle Slope 0 Jul 21, 2011 06:46 PM
