Old Jan 20, 2013, 10:33 PM
Want2B3D's Avatar
Joined Nov 2012
Whoops!
OS max fx 46
Prop came off in flight motor redlined and shut down the shaft has movement in and out not a lot is this bad, did I blow the motor, what can I check to see if I messed it up? Thanks for advice.
Want2B3D is offline Find More Posts by Want2B3D
Old Jan 20, 2013, 11:37 PM
Joined Jun 2011
Probably bearings
datsunguy is offline Find More Posts by datsunguy
Old Jan 21, 2013, 01:18 AM
DarZeelon's Avatar
Israel, Ramat HaSharon
Joined Nov 2003
Wannabe,
The engine did not 'redline'; it more likely reached, or exceeded 30K for a very short time.
When such a mishap occurs, one outcome can be that nothing happened...
But another possibility is that one (or both) bearing shed its cage.
The con-rod could also snap.
The bearings in that engine are rated for pretty high RPM. The 6902 is rated for 34K (NTN for 28K!) and the R6Z is for 37K.
You will have to take your engine apart, since if you try running it with a shed cage, it will be disastrous.
Replacing a bearing is not very difficult and they are inexpensive, if you don't insist on OEM (or Boca).
DarZeelon is offline Find More Posts by DarZeelon
Old Jan 21, 2013, 05:31 AM
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
os 46
More than likely nothing is wrong with your engine, it is normal to have a small amount of play. If you are not familiar with working on engines, do not take it apart. Turn it over by hand and if all feels ok, go ahead and run. In general, model engines are very durable.
ronwc is online now Find More Posts by ronwc
Old Jan 21, 2013, 06:15 AM
DarZeelon's Avatar
Joined Nov 2003
Removing the back-plate and examining the rear bearing at either side of the crank, while rotating the crankshaft, should be enough to diagnose a shed bearing cage.
You'll be able to see the con-rod too, of-course.
That's all the 'taking apart' that you'll need to do.
Old Jan 21, 2013, 08:11 AM
Want2B3D's Avatar
Joined Nov 2012
I will take the backplate off and check it out it still turns over just has play and I can't remember if its more play or not
Old Jan 21, 2013, 06:10 PM
Want2B3D's Avatar
Joined Nov 2012
Everything looks good bearings and conrod is good turns over nice I think it's okay just lost the thrust washer
Pro ARF Extra 33oL Scale/stunt /w OS FX .46 dankar04 Non R/C Items (FS/W) 0 Jan 19, 2013 03:20 PM
Sold OS 46 FX Engine for sale....price reduced arik434 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 14, 2013 08:05 PM
Sold OS Max 61 fx Os max 46 fx Dragon 2 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Oct 09, 2006 06:20 PM
Wanted OS Max .46 FX or AX OR Evolution .46 NT bkahuna Aircraft - Fuel - Airplanes (FS/W) 0 Dec 05, 2005 08:01 PM
$1 OS MAX .46 FX R/C Glow Aircraft Engine eBay LexTalionis Aircraft - Fuel - Airplanes (FS/W) 4 Sep 15, 2004 07:03 PM
