Old Feb 24, 2013, 12:54 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Sweet! That flies great. How much throttle were you using?
If that was full throttle, you will gain some speed with the repitched 3 blade at the expense of flight time.
You should send some pics to Guillows, they will add it to the builder's gallery.
Glenn
glewis is online now Find More Posts by glewis
Old Feb 24, 2013, 01:14 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
thanks glenn,i can cruise around @ 1/2 throttle and most of the flight was @ 3/4 throttle.i did some rolls and loops @ first full throttle but the footage wasn't the greatest.there was a few min. of battery left when i brought it in so i'm looking forward to the 3 blade.
i will look into the guillows gallery
meltor is offline Find More Posts by meltor
Old May 07, 2013, 02:17 AM
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Cool build I just bought this kit the other day and was thinking of doing the same thing with the guts I pulled out of a little Sukhoi micro.
cbarnes0061 is online now Find More Posts by cbarnes0061
Old May 07, 2013, 03:24 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
i'm sure the sukhoi running gear would fly this model great. one thing though, gut out the fuse formers if you do this build .since there's no rubber power they don't need to be as beefy as they are and this build did take 1/4 oz in the nose to get c/g. I could have gutted out of the tail and aft fuse to get it.
Old May 07, 2013, 03:45 PM
Flying Low
Joined Mar 2012
How much material would you suggest leaving and should I remove it from the formers and the main spars(not sure if that's what it's called but the piece that runs the length of the cuz on top and bottom that all the formers attach to) or should I remove it just from the formers?
Old May 07, 2013, 03:46 PM
Flying Low
Joined Mar 2012
Also did you glue yours together with CA or wood glue.
Old May 07, 2013, 04:04 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
I use medium ca and activator.here is a pic of my bf109 kit 401 where you can see how much I gutted from the aft fuse formers.you can take out quite a bit and sand 1/4 of the 1/16 spars away.there will still be plenty to keep the air frame ridged.
Old May 07, 2013, 04:36 PM
Flying Low
Joined Mar 2012
Ok thanks. On yours how do you access your radio gear if you need to get to it?
Old May 07, 2013, 09:50 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
well, that is a problem, but only if something goes wrong.if I had to I would just xacto whatever covering and balsa I need to and patch it up when the repair is made..so far so good though after nearly 2 dozen flights with no issues except slamming into the side of my truck after a crummy hand launch last winter.even then it just tossed the spinner and broke a couple of wing spars.i was able to ca them with a pin hole tip and some thin ca.you could make the wing bolt on like Glenn did on his FW190.
these air frames are tough! I have had more than a few cartwheel landings with these planes and minimal damage where as i'm sure I would have torn a wing with my pz um p-51.
Old May 07, 2013, 10:24 PM
Flying Low
Joined Mar 2012
ok cool. I'm thinking I might try and either bolt the wing on or pin it at the front of the wing and do something similar the the canopy quick release at the back.
Discussion About Converting Guillows Kits to Electric RC E-Challenged Scale Kit/Scratch Built 12 Dec 17, 2012 09:22 AM
Discussion How to Hand Launch RC Foamie Plane Mustang GWS Me109 Skyfun Delta Beaver TheLeabres Parkflyers 0 Jun 10, 2012 05:03 AM
Discussion Guillows Bf-109 Kit 505 Conversion admiral_adonis Scratchbuilt Indoor and Micro Models 28 Sep 28, 2011 05:32 AM
Build Log Messerschmitt BF-109 Guillows Kit 505 Tuctronics Scratchbuilt Indoor and Micro Models 18 Sep 27, 2011 09:28 AM
For Sale Me109 Image CD of 109G-2 black six 505 pics 109Mechanik Aircraft - General - Miscellaneous (FS/W) 5 Jul 14, 2006 02:06 PM
