Old Dec 14, 2012, 10:51 AM
United States, MA, Boston
Joined Oct 2010
Question
Best Foam for Filling and Building
I realize this may seem like a simple question, but for some reason I can't seem to hunt down a finite answer.
I'm doing a project that require some ares of a balsa, built up model to be filled or shaped out of foam. I'm wondering:
1. What is the best kind of foam for light weight, strong, and easy shaping?
2. Where can I buy it (Home Depot, or rc store)?
3. Can I put iron on covering on it without worrying about melting it?
nfsiv is offline Find More Posts by nfsiv
Old Dec 14, 2012, 11:41 AM
Staffs, UK
Joined Nov 2003
I generally use Dow Floormate, commonly known as "blue foam". It's easy to shape and reasonably light. Whether it's strong enough depends on what you're intending to use it for. It doesn't like very high heat so Monocote might be tricky but lower temp films like Ultracote, or over here Solarfilm, are usually o.k.
No idea where you can buy it in your part of the world, sorry.
Steve
slipstick is online now Find More Posts by slipstick
Old Dec 14, 2012, 12:58 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
The blue or pink expanded polystyrene foam is the best choice without getting involved with specialty foams. You can buy it easily at any of the larger lumber and hardware yards like Home Depot or Lowes.
It does not like heat though. It's best to stretch a heat shrink covering over it and stick it just around the edges onto the wood. Or you could try insulating it from the heat of the covering iron by applying a layer of 4 oz glass cloth to the foam using some sort of light adhesive like a spray glue or even common glue stick. You don't need to use resin since the idea is that the cloth would be strictly a bit of an insulative separator between the foam and the heat used to shrink the plastic covering. You'd still want to only stick the covering firmly to the wood around the edges and not to the foam or cloth layer. And when you shrink the foam get onto it and back off FAST. Don't fuss about with it or the heat will extend down through the glass cloth and insulative air and get to the foam. If there's a wrinkle or two that needs extra attention let things cool off first then go at it again for a few more seconds.
Another option would be the foam used for dry and fake flower arrangements. I've never worked with this foam but I know you can get it in blocks and other shapes from craft stores such as Micheal's. You'd need to get a bit and try it out to see if it's as heat sensitive as the extruded polystyrene stuff.
BMatthews is offline Find More Posts by BMatthews
Old Dec 14, 2012, 01:47 PM
Joined Oct 2010
Thanks Bruce and Steve. I expected the standard insulating foam was the way to go, but did not know about the heat concerns. Glad to have learned about it before I was putting the finishing touches on a plane.
Old Dec 14, 2012, 03:17 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Don't try it.The stuff has zero strength,you can literally push your finger in to it.
Stupot46 is offline Find More Posts by Stupot46
Old Dec 14, 2012, 10:42 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Well, yeah. But the same is true of the blue and pink stuff. At least to the extent that if you don't exercise some restraint in handling the final products that you'll leave dents in the surface.
But you do raise a valid point. And it suggests that actually applying some form of glue or other "resin" to some smoothed over fiberglass cloth done to insulate the foam might not be a totally bad option. The skin thus created could provide the sort of strength needed to avoid damage due to handling incidents.
Old Dec 15, 2012, 12:31 AM
“Do it Right The First Time!”
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I really like the Owens-Coring Foamular 250. (pink) Yes, it may dent, but you would be hard pressed to put your finger thru it. You might break your finger first. Great to carve or hot wire, easy to sand. You can take it down with 60-80 grit to start, and a 220 grit will give a nice smooth finish
If you hold a heat gun directly on it, it will deform. Never tried it with a covering, only have fiberglassed it. depending on the store, you may have to buy a full sheet. 4'x8' thicknees will vary by store
Should be plenty of Home Depots on the east coast.
CoolerByTheLake is online now Find More Posts by CoolerByTheLake
Discussion Best glue for repairing planes (foam)? RPTheLefty Electric Plane Talk 41 Jan 25, 2014 05:05 PM
Help! foam filled, Carbon braided sleeved tube master_bebe Scratchbuilt Indoor and Micro Models 12 Aug 01, 2012 09:08 AM
Discussion Best finish for foam obechi covered glider wing Graham 65 The Builders Workshop 8 May 06, 2012 02:01 AM
Discussion Best Material for Small Foam Repair? swimman Foamies (Scratchbuilt) 3 Apr 13, 2012 05:11 PM
What is good for Fan Fold Foam Foam Gap Filling? RC Pete Foamies (Kits) 4 Jul 21, 2002 12:29 AM
