Old Feb 09, 2012, 05:23 PM
United States, AZ, Tucson
Joined Nov 2006
Help!
Optical RPM Sensor Mounting Challenge
Want to mount/glue on DA-85 Hall Effect pickup housing. I want to sense back of black/white prop spinner plate for RPM logging.
What glue or attachment method works in high vibration with little surface to grip, Zip ties will not fit securely.
DA ignition sensor housing is red plastic material. Will ATV Red silicone sealant hold it? Anyone have success or other location to sense prop rpm hub or spinner surface?
Capt Dave is offline Find More Posts by Capt Dave
Old Feb 10, 2012, 07:04 AM
Saline, MI
Joined Jul 2006
My 2 cents.
1) I'd switch to the magnetic RPM sensor. If the red housing really is some kind of hall effect sensor, then there probably is some kind of magnet on the rotating prop hub it could read.
2) I'd take advantage of that screw that shows up in you picture. Make a sensor bracket with some brass sheet and square tubing that the screw holds in place. Should work for either sensor.
dhares is offline Find More Posts by dhares
Old Feb 10, 2012, 10:51 PM
Joined Jun 2010
I'd make a little braket and attach it to that screw.
Here's what I did with a hall effect sensor:
Terry Keeley is offline Find More Posts by Terry Keeley
Sold EAGLETREE Powerpanel LCD Display and Optical RPM sensor kookboy Aircraft - Electric - Power Systems (FS/W) 10 Apr 04, 2007 10:19 AM
