Old Jan 18, 2012, 12:51 PM
Joined Jul 2011
Help!
Paris v4 + Bma180 + wmp
Hi guys,
I'm trying to put my quadcopter to fly but I'm having a major issue that i can't figure out...if i connect one of the esc to the CH 3 on the radio receiver, i can accelerate it....everything's fine....but when i put everything together, the only way to get power to the arduino is through the ftdi, if i just use the battery, nothing....dead :x
any thoughts on what it could be?
thank you so much
antpgomes is offline Find More Posts by antpgomes
Old Jan 18, 2012, 01:19 PM
USA, CA, Fontana
Joined Mar 2005
Gui
DO you see anything on the GUI?
actionplus is online now Find More Posts by actionplus
Old Jan 18, 2012, 01:23 PM
Joined Jul 2011
I got this, connected through ftdi....no receiver or esc's though...
Old Jan 18, 2012, 01:33 PM
USA, CA, Fontana
Joined Mar 2005
Gui
SO, it look like it is reading the sensors.
Make sure there are no blades, since you are setting this up.
Did you try arming the board? Throttle stick down and to the right.
Old Jan 18, 2012, 01:39 PM
Joined Jul 2011
not quite because i can't get the arduino to power up using just the lipo...and i the wiring seems fine (i never put the blades at anytime btw )
Old Jan 18, 2012, 01:44 PM
USA, CA, Fontana
Joined Mar 2005
V4
Not sure about the V4 board. But I think there is a jumper or something at the bottom to make the board use separate BEC or use the power from esc.
Check the wiki from www.multiwiicopter.com
Old Jan 18, 2012, 02:27 PM
United Kingdom, England, Portsmouth
Joined Jan 2009
see attached image, also some of your solder joints on your pro mini are not very good either.
rcta15 is offline Find More Posts by rcta15
Old Jan 20, 2012, 05:00 PM
UK, West Lindsey
Joined Jul 2010
Hi, I also have this board. You need to either solder the bridge that is top right in the above image, or use a separate supply. The bridge basically connects the +5v from your ESC to the supply for the main board. This is the way I have mine configured - without any noise problems.
Iain
refractions is offline Find More Posts by refractions
Discussion Multiwiicopter how to connect bmp085 hmc5883l and bma180 to paris board 3.0 nicepix4u Multirotor Talk 4 Mar 02, 2012 09:51 PM
Wanted Avroto 2814 Short Shaft + esc 30A + PARIS - Quad/Tri/Hex/YSiix SiriusŪ600MP+ - v4.0 L mike76 Aircraft - Electric - Multirotor (FS/W) 0 Dec 07, 2011 07:52 PM
Help! paris v4 board trimming led what voltage rcta15 Multirotor Talk 0 Nov 21, 2011 10:32 AM
Sold PARIS V.3 Plug and Fly board with LLC/BMA180 OCaerial Aircraft - Electric - Multirotor (FS/W) 1 Aug 20, 2011 09:11 PM
Sold Paris Board, Arduino, BMA180, WMP For Sale kasra Aircraft - Electric - Multirotor (FS/W) 8 May 29, 2011 09:57 PM
