Old Sep 16, 2011, 05:41 AM
100% crasher
Sverige, Skåne Län, Hässleholm
Joined Sep 2011
larger foam plane project
new member but not a newbie to the flying at all (been crashing a LOT- LOL!!)
recently I have some ideas about building a slightly bigger plane in foam board.
it will be a full fuselage body and wings with profile. it might be so big so that it will be needed with split wings, so, any suggestions about a smart, simple wingjoiner arrangement.
fin and stab will be from balsa, i think.
this will all take some time, my building is not the fastest since there is other things going around as well.
//jj
CU
alfa166 is offline Find More Posts by alfa166
Old Sep 16, 2011, 05:55 AM
zetland76's Avatar
Ilkley, UK
Joined Apr 2007
Hi alfa,
I build 1/10scale PSS models from Styrofoam and have used 5mm foamboard for fins and tailplanes. Beware! If you paint or glue this board, do both sides straight away and hang it up to dry. It will warp dead easy if you do one side first and wait.
Will follow with interest your problem re wing joining as I have a similar problem with my MIG15.
zetland76 is offline Find More Posts by zetland76
Old Sep 16, 2011, 07:51 AM
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
The problem may be that we are in different parts of the World. Here I found that a carbon arrow shaft fits perfect into an aluminum arrow shaft. Carbon arrow = wing spar, aluminum arrow (short piece) = fuselage mounting tube.
Maybe you could find some rod and tubes made from something else and do a similar wing joiner arrangement.
Fred
Freddie B is offline Find More Posts by Freddie B
Discussion New Project Idea? 2 Meter Foam F3A Plane :) Team3D Foamies (Scratchbuilt) 7 Jun 22, 2012 10:28 AM
Discussion Can you help me build a larger foamy 3D plane keithy351 3D Foamies 3 Oct 07, 2011 09:09 AM
Sold Sure Flite Piper J-3 Cub Injection Molded Foam Plane Merk Aircraft - Electric - Airplanes (FS/W) 2 Sep 14, 2011 09:56 PM
Found BF109 .40 size or larger Non-foam planebldr Aircraft - Electric - Airplanes (FS/W) 0 May 01, 2011 11:26 AM
