Old Feb 08, 2011, 10:14 PM
Joined May 2010
Jumping back in to electric 3D
Getting back into it and unsure of all of the advances in electric power systems (glad to see its cheaper now) after three years off. I bought the Aeroworks 260 electric profile, two years ago and assembled everything, less the motor. I expect the weight to come in around 20oz or so. I'm looking for plenty of power for nothing but 3D - I'm sure I'll be rusty, but hope it's like riding a bike.
I would like to order from Hobby King as I need new batteries and charger as well........please help with the following :
Motor
Battery Brand - looking for 1500, 20-25c 3 cell ???
Charger
Prop
Looks like I made need a new esc as well....
Next plane will likely be the AJ 42" Slick....
kirkg is offline Find More Posts by kirkg
Old Feb 09, 2011, 08:41 AM
United States, CO, Delta
Joined Dec 2010
That is one sweet little plane! However, a 1300 mAh is the absolute largest pack that will fit. Even the rhino 1350 20c was too large. I had to cut the hole in the airframe bigger to get it in.
I used the mystery 20 esc.
I used this motor http://hobbyking.com/hobbyking/store...idProduct=4701
Personally, I would probably just go to hobbypartz.com and get a low kv 400 size motor and their blue lipo 1300 mAh 20c batteries. They also sell the b6 charger, which is what I use. As far as prop, I used a 9x3.8 sf with the hacker style but if you go with hp I would go with the largest diameter, lowest pitch prop they recommend for that motor.
Good luck. It is probably the funnest plane I have ever flown! I ended up selling it after I cart-wheeled it about a dozen times and got tired of fixing the fuse. It's tough and is a great 3d trainer but it is balsa and will break.
Micah
The_Tinker is offline Find More Posts by The_Tinker
Old Feb 09, 2011, 05:17 PM
Pain? I know pain!
Weldon Spring, Missouri
Joined Mar 2005
I have that hacker clone on mine and it works well. I'm using the 3s Turnigy 1300's as well and did need to cut the battery hole out to fit the packs.
Up in the air brand new for under 150 with 3 packs and 2 extra servos just in case is hard to beat.
Tom
litespeed is offline Find More Posts by litespeed
Old Feb 10, 2011, 02:03 PM
Joined May 2010
Tom
Would you mind posting a picture of your setup so I can see the type of connectors you are using?
What kind of flight time are you getting out of the 1300?
Greg
Old Feb 10, 2011, 04:03 PM
Pain? I know pain!
Joined Mar 2005
10 min flying sport flights easy and 3D for 7min.
Fun plane but as said....don't hit the ground. You will only do it once!
Tom
Old Feb 10, 2011, 10:46 PM
Joined May 2010
Tom
Thanks Tom - what type of prop adaptor is that...where did you get it?
I talked to one of my buddies today that I flew with a few years ago and they are getting 2.4 dsm2 receivers through HK for 8 bucks. http://www.hobbyking.com/hobbyking/s...dProduct=12586
They just shrink wrap it once they get it...
Old Feb 11, 2011, 12:05 AM
Joined Feb 2011
Tom
Perfect!
swindy43 is offline Find More Posts by swindy43
Reply With Quote  (Disabled)
Old Feb 11, 2011, 05:53 AM
Pain? I know pain!
Joined Mar 2005
The motor comes with 2 types of prop adapters, this break away "prop saver" and a collet type. http://hobbycity.com/hobbyking/store...idProduct=4701 try to beat that deal for under 10 bux!
Servos I used are, http://hobbycity.com/hobbyking/store...?idProduct=662
Batteries, http://hobbycity.com/hobbyking/store...idProduct=9493
ESC, http://hobbycity.com/hobbyking/store...dProduct=13429
Prop, http://hobbycity.com/hobbyking/store...idProduct=7158
Make sure you have an account before you shop and then log in. It gives you cheaper prices but the shipping is still the same.
I have one Orange Futaba Fasst Receiver and I can't tell the difference on the bench as far as speed or resolution. For $29.99 (compared to $100!) I had to try one but it hasn't been in the air yet.
Tom
Discussion best 3d/IMAC electric airplane in the 30"-50" class tesla000 Electric Plane Talk 1 Oct 12, 2010 01:57 AM
Discussion Need some help Jumping back in... nismoron Racing Boats - Electric 20 Jul 24, 2010 02:49 PM
Discussion E-flight park 400 jumping back and forth inedesca Power Systems 4 Jul 29, 2006 12:12 AM
Discussion Jumping back in Fatdog Racing Boats - Internal Combustion 1 Feb 19, 2006 05:29 PM
