Old Oct 19, 2010, 05:37 PM
Alaska
Joined Feb 2010
Help!
Tx Battery Discharged
Argh!!! I left my Tx on overnight and discharged my battery. Is there anyway to get it to take a charge again?
Thanks.
Williwaw is offline Find More Posts by Williwaw
Old Oct 19, 2010, 05:48 PM
dmcquinn's Avatar
Chesterfield (St.Louis) MO
Joined Jan 2004
Use a slow charger - like the wall wart 50 mA charger that probably came with the transmitter. If it's a NiMh or NiCd pack (most likely) it will be fine.
dmcquinn is offline Find More Posts by dmcquinn
Old Oct 19, 2010, 05:52 PM
Alaska
Joined Feb 2010
It's a Rhino 2620mAh 3S 11.1v Low-Discharge Transmitter Lipoly Pack. Would I really want to use the NiCd charger that came with my Tx on it...would that work?
Old Oct 19, 2010, 05:54 PM
So. Cal.
Time to shop for a new TX battery. There are ways to breathe some life back into lipolys but the damage is done. As TX power is so vital, I would never trust it again.
One of the reasons to stick with NiXX. LSD NiMH (Eneloops, etc.) have the long charge retention of lipolys but none of the headaches.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Oct 19, 2010, 05:56 PM
So. Cal.
Bad idea. If left plugged in for an extended period of time, overcharge and fire will ensue as NiXX chargers do not have proper termination of LiXX chemistry cells.
Mark
Old Oct 19, 2010, 06:12 PM
dmcquinn's Avatar
Joined Jan 2004
No, definitely not. I (incorrectly) assumed it was NiMh or NiCd. When you run down a LiPo, it is generally ruined.
Old Oct 19, 2010, 06:15 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Top of most Forums have Stickys which are often helpful if read.
My battery is dead - HELP" info.
http://www.rcgroups.com/forums/showthread.php?t=1074181
I agree that low self dischge NiMH cells are a much better choice and I use Sanyo Eneloops in my Transmitter.
everydayflyer is online now Find More Posts by everydayflyer
Old Oct 19, 2010, 06:40 PM
Alaska
Joined Feb 2010
Oh, you mean the sticky thread that says, "My battery is dead - HELP info"....oops, I did not see that I did do a search though
Anyway, thanks for your help. I tried the NiMH method and it started to puff so I have come to terms with the "inevitable". Thanks again for your help all.
Does a charged battery weigh more than a discharged one? tim hooper Batteries and Chargers 69 Oct 26, 2011 05:42 PM
For Sale 7C futaba fasst TX with lipo TX battery losifanatic Aircraft - General - Radio Equipment (FS/W) 1 Oct 10, 2010 02:13 PM
Discussion over discharged battery cowboychris Micro Helis 1 Jun 06, 2007 10:03 PM
Discussion Deep discharged TX battery, multiplex Inverted_Fly Radios 4 Mar 07, 2006 10:10 AM
How to check battery state..charged/discharged with a DVM? Double Dutch Batteries and Chargers 9 May 15, 2003 06:29 PM
