Joined May 2011
All my buddy-codes on RCSearch.info
HobbyKing HK-922MG Digital Metal Gear Servo 1.8kg/ 12g/ 0.07sec ![]() $9.02* (buddy price -24%, -$2.82) 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Orange) ![]() $1.34* (buddy price -57%, -$1.8) TURNIGY 3A UBEC w/ Noise Reduction ![]() $4.14* NTM Prop Drive Series 28-30A 750kv / 140w ![]() $14.22* (buddy price -5%, -$0.77) 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Flouro Yellow) ![]() $1.34* (buddy price -57%, -$1.8) Hobby King Quadcopter Power Distribution Board ![]() $2.28* (buddy price -43%, -$1.71) |
Joined Feb 2013
Here are Hobbyking Buddy Codes from my last purchase:
1. PRODUCT ID 9310000062 Durafly Slick 360 V2 3s Micro 3D 490mm (PNF) buddy price $62.32 http://www.hobbyking.com/buddy.asp?c...7-8E84F86BEE94 2. PRODUCT ID: 9210000035 Turnigy nano-tech 180mah 3S 25~40C Lipo Pack buddy price $4.72 http://www.hobbyking.com/buddy.asp?c...8-1746075F82E8 3. PRODUCT ID: 9310000011 Durafly Micro Series - Replacement Propeller Adapter buddy price $1.94 http://www.hobbyking.com/buddy.asp?c...A-6DBC7D3DF3D6 4. PRODUCT ID: 9310000010 Durafly Micro Series - Replacement Propeller(5pcs) buddy price $1.33 http://www.hobbyking.com/buddy.asp?c...C-F7E6E3613836 |
Some FPV stuff
![]() Fat Shark BASE SD FPV Headset only $242.00 http://www.hobbyking.com/buddy.asp?c...A-1991680F9137 ![]() ZIPPY Flightmax 3000mAh 4S1P 20C only $14.37 http://www.hobbyking.com/buddy.asp?c...0-9F25478567A5 ![]() On Board Lipoly Low Voltage Alarm (2s~4s) only $1.79 http://www.hobbyking.com/buddy.asp?c...1-E2B1FAFD3CB4 ![]() Mini OSD System w/GPS Module $20.63 http://www.hobbyking.com/buddy.asp?c...7-3C8C6271E815 ![]() 1/3-inch SONY CCD Video Camera (NTSC) only $30.42 http://www.hobbyking.com/buddy.asp?c...2-33B67A9AAF07 ![]() 2.8mm F:2.0 Turnigy Micro FPV Camera Lense only $4.96 http://www.hobbyking.com/buddy.asp?c...C-8B0695FC5F3C ![]() 2.5mm F:2.0 Turnigy Micro FPV Camera Lense only $6.17 http://www.hobbyking.com/buddy.asp?c...4-691A199D9788 ![]() Buddy Code http://www.hobbyking.com/buddy.asp?c...6-002E2B2961DF |
Joined May 2011
Order from the international warehouse. These codes should be good until March 24h.
10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) http://www.hobbyking.com/buddy.asp?c...3-E1D675A3EB79 Atmel Atmega Socket Firmware Flashing Tool http://www.hobbyking.com/buddy.asp?c...1-5BC0D6A1535B Twin pack charge lead (2 x 3S)6S w/ XT60 http://www.hobbyking.com/buddy.asp?c...D-8007C073FE8C Turnigy Heat Shrink Tube 25mm Transparent (1mtr) http://www.hobbyking.com/buddy.asp?c...4-7166374097D7 Turnigy Pure-Silicone Wire 18AWG (1mtr) Red http://www.hobbyking.com/buddy.asp?c...2-D2BCFD71F4A7 Wire Mesh Guard Black 6mm (1mtr) http://www.hobbyking.com/buddy.asp?c...0-E479920A0F82 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Green) http://www.hobbyking.com/buddy.asp?c...F-FC1C2E769064 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Black) http://www.hobbyking.com/buddy.asp?c...9-39A4E7D764AD M3 Nylon Nut (10pcs/bag) http://www.hobbyking.com/buddy.asp?c...D-DA99AEB98875 Hobbyking Multi-Rotor Power Distribution Board (DIY 8 x output PCB) http://www.hobbyking.com/buddy.asp?c...0-09DA7A7A3522 Strong Rare-Earth Button Magnets (10pcs/set) http://www.hobbyking.com/buddy.asp?c...C-BE8B4E2542B4 Simple Prop Balancer http://www.hobbyking.com/buddy.asp?c...E-96BE17273C0F |
Ottawa, Canada
Joined Jul 2004
Turnigy nano-tech 260mah 2S 35~70C Lipo Pack (E-flite EFLB2002S25 micro series compatible) $3.61* $4.99 normal price
![]() Turnigy nano-tech 300mah 1S 45C Lipo Pack (Suits FBL100 and Blade mCPx) $2.40* $5.49 normal price
Joined Apr 2012
Polyester velcro
http://www.hobbyking.com/buddy.asp?c...6-7C479EAEAACE |
Joined Apr 2012
Hobbyking ESC 18-20A
http://www.hobbyking.com/buddy.asp?c...6-7C479EAEAACE Polyester Velcro http://www.hobbyking.com/buddy.asp?c...6-7C479EAEAACE Turnigy Battery strap http://www.hobbyking.com/buddy.asp?c...6-0316AFC0FD16 APC style prop 8x4 http://www.hobbyking.com/buddy.asp?c...7-B1B1B17AD10D Ultra thin foam glue http://www.hobbyking.com/buddy.asp?c...B-70D3596B984C |
On Board Lipoly Low Voltage Alarm (2s~4s) ![]() $1.80* (buddy price -6%, -$0.12) Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr) ![]() $2.25* (buddy price -6%, -$0.14) HobbyKing Cutting Mat (USA Warehouse) ![]() $6.22* (buddy price -6%, -$0.41) Turnigy 1000mAh 3S 20C Lipo Pack ![]() $4.51* (buddy price -18%, -$0.98) Turnigy 1000mAh 2S 20C Lipo Pack ![]() $3.66* APC Style Propeller 8x4 (2 pc) ![]() $1.36* Hobbyking SS Series 18-20A ESC ![]() $5.96* Female JST battery pigtail 12cm length (10pcs/bag) ![]() $1.48* (buddy price -7%, -$0.11) PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) ![]() $1.40* (buddy price -12%, -$0.19) |
Joined Dec 2008
http://hk.rc-international.info/swarm/ http://rcsearch.info/hobbyking/buddy/ Note to buddy posters> if you want us to use your codes **PUT UP THE $ SAVINGS** |
Joined Dec 2012
Turnigy 2200mAh 3S 20C Lipo Pack:
http://www.hobbyking.com/buddy.asp?c...6-A635F076055F 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Orange): http://www.hobbyking.com/buddy.asp?c...5-9B91BB53A667 Hobbyking DC-4S Balance Charger & Cell Checker 30w 2s~4s: http://www.hobbyking.com/buddy.asp?c...2-6FB1E219A94D Simple Prop Balancer: http://www.hobbyking.com/buddy.asp?c...A-D5782D63C71B |
325mm Fiber Glass Main Blades
http://www.hobbyking.com/buddy.asp?c...5-0343DDE5E96A http://www.hobbyking.com/buddy.asp?c...6-BE3ACB2D42ED GT450PRO Feathering Shaft (51x4mm) 2pcs http://www.hobbyking.com/buddy.asp?c...A-F064EBAA4F7E GT450PRO Skid Pipe http://www.hobbyking.com/buddy.asp?c...9-D568D755A656 GT450PRO Main Rotor Thrust Bearing Set (3x8x3.5mm) http://www.hobbyking.com/buddy.asp?c...1-C3EC65357B12 GT450PRO One Way Bearing (1pc) http://www.hobbyking.com/buddy.asp?c...5-7DC38AD4AAD8 GT450PRO Bearing (11x4.98x4.96mm) 4pcs http://www.hobbyking.com/buddy.asp?c...4-0D39E6EB7BC7 GT450PRO Bearing (7.98x2.98x3.95mm) 4pcs http://www.hobbyking.com/buddy.asp?c...0-7157CF9404C9 10 x BM2*14 Screw - 118B, A2023T, A2029 and A2035 http://www.hobbyking.com/buddy.asp?c...8-E1429FAB809A valid until 29.3.2013 |
| Thread Tools | |
| Alert HobbyKing buddy codes! | M40R | HobbyKing | 35 | May 17, 2013 07:15 AM |
| Link Hobbyking rarebare race package $10 discount buddy code | Libtekguy | Hot Online Deals | 0 | Mar 08, 2013 12:25 PM |
| Discussion hobbyking buddy code! | IceRain29 | HobbyKing | 31 | Mar 06, 2013 11:05 AM |
| Yippee! Hobbyking buddy code 3-6-13 | volumax | Hot Online Deals | 0 | Mar 06, 2013 02:45 AM |
| Discussion my current hobbyking buddy codes | crashtestheli | HobbyKing | 1 | Jan 18, 2013 08:01 PM |
