Old Oct 09, 2014, 10:30 AM
Oman
Joined Aug 2014
Question
Ratio of wing span to the length of fuselage
Guys am planing to build a scale airplane that has ratio 1:1 (wing span to length of airplane) the goal to slow fly and aerobatic
So am asking is ratio 1:1 going to be sanitary or should minimize the length of fuselage??
The plan is 55" wing span to 55" fuselage including tailplan
ali74 is offline Find More Posts by ali74
Old Oct 09, 2014, 11:38 AM
yank and bank!!
Joined May 2013
The ratio of wingspan to overall length isn't nearly as critical as other things such as wing loading.
Incidentally a 55" ws plane is a lot of plane for a beginner...
failboat is offline Find More Posts by failboat
Old Oct 09, 2014, 12:13 PM
Oman
Joined Aug 2014
I believe 55" not for beginner although I have scratching F22 and extra 300 ready for power system
I like building scale models even with no clue about dimensions and sizes at least they have aircrafts shape to put them in my room for show
Old Oct 09, 2014, 12:57 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Slow flying is easier to achieve with light-weight models, i.e. low wing loading, the size isn't too important.
The ratio of wing span to fuselage length is not really important, as the same ratio could also cover a model with a long nose or a short nose.
eflightray is offline Find More Posts by eflightray
Old Oct 09, 2014, 02:56 PM
Oman
Joined Aug 2014
Actually I like airplanes which having large size more than small models
Old Oct 12, 2014, 08:39 AM
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
They also means a lot of pain when you crash.
Teddy Ong is offline Find More Posts by Teddy Ong
Old Oct 12, 2014, 08:59 AM
Oman
Joined Aug 2014
Am using foam boards so no pain rather than cost 10$ for two sheets and that of sure if the crash not killing the power system
Help! ME109 fiberglass fuselage and wing 80"wing span p3arljam Fuel Warbirds 1 Feb 19, 2014 06:20 PM
Discussion WIng Span to Length Ratio roo_ster Foamies (Scratchbuilt) 2 Dec 14, 2012 08:40 AM
Question Is there an aileron length to flap length ratio? Lou Sailplane Talk 0 Jun 13, 2011 08:52 PM
Help! Request for twisty wing plane span and aspect ratio (or wing area) data Sled Driver Slope 17 Oct 28, 2006 11:44 AM
acceptable fuse-wing length ratio electrohead Power Systems 5 May 02, 2001 03:47 PM
